LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Dynamometer Results & Comparisons (https://ls1tech.com/forums/dynamometer-results-comparisons-65/)
-   -   1000 rpm's MISSING (https://ls1tech.com/forums/dynamometer-results-comparisons/489839-1000-rpms-missing.html)
WhtLtngZLS1 Apr 16, 2006 10:47 AM
1000 rpm's MISSING
1 Attachment(s)
I just installed the TR230 cam straight up with a set of stage 2 5.3l heads in my 98 camaro and I had the car tuned and the powerband falls off at 5600 rpms instead of 6800 rpms! The fuel injectors and pump are stock. I replaced the manifold with ls6 intake and the tb is stock. The exhaust I am running is hooker headers with hooker y-pipe and loud mouth back! I called thunder racing and they are telling me to degree the cam but you can't degree a cam with hydraulic lifters so I am stuck but if someone has done it in the car if you could let me know how that would be awesome! The dyno graph is below!
foff667 Apr 16, 2006 11:25 AM
off a tooth maybe?
© 2026 MH Sub I, LLC dba Internet Brands
