LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Dynamometer Results & Comparisons (https://ls1tech.com/forums/dynamometer-results-comparisons-65/)
-   -   Ported TB and Descreened MAF result's (https://ls1tech.com/forums/dynamometer-results-comparisons/610271-ported-tb-descreened-maf-results.html)
Slowhawk Nov 17, 2006 11:54 AM
2 Attachment(s)
Got bored today and headed to the dyno.Car is the same I posted before which is a stock 02 346 with Kooks,Magnaflow and 4000 stall. All runs are with a locked converter,no timing changes and A/F dialed in.Engine temp was 185' on the beggining of each pull.
Run 5 is the before -It is from last time but the before pulls today were exactly the same #'s and follow perfectly,just the old graph was smoother for comparison(had noise on the pulls)
Run 9 -changed to a ported TB done by myself.No A/F changes needed.
Run 12- removed MAF screen,car went .6 point leaner and lost 15hp at first.I dialed the A/F back to the other's and gained some back but still lost hp.
So,on a stock/header car the ported TB was worth 8hp/2tq with most of the gain up top and a descreened MAF lost hp.I know a MAF mod is good on H/C cars but it just doesn't work on these lower hp cars.
Graph 1 shows the difference between the 3 and graph 2 shows the HP loss with the MAF :)
Cerebrex Nov 17, 2006 12:07 PM
Damn MAF descreening. Those TB numbers surprised me though. Good work.
TXZ28LS1 Nov 17, 2006 12:36 PM
cool man.. nice to see what kind of results we can expect with a TB... right on!!
Alvin Nov 17, 2006 01:21 PM
I've pulled the screens out of a few cars on the dyno during runs and they have all picked up 5rwhp or so after getting the +.2-4 AFR back down
DannoWS6 Nov 17, 2006 01:33 PM
I gained about 8hp as well with a shaner s2 TB, when I only had bolt on's.
Slowhawk Nov 17, 2006 01:56 PM
I've always gained on H/C cars but it seamed like this header car didn't like it.I couldn't do the test anymore perfect than this. :)
slimcracka Nov 17, 2006 07:19 PM
good work.. i knew the ported tb was a good buy.. about 10 dollars a rwhp
98camaroLS1M6 Nov 17, 2006 11:58 PM
Nice results!
Houston999 Nov 18, 2006 12:03 AM
I did the same on many cars they all gain about 4-7 hp taking the screen of.
ShevrolayZ28 Nov 18, 2006 12:22 AM
Where's my Dremmel?! :judge:
Checkmate Nov 18, 2006 10:41 AM
great test. :)
DO you have results from when you tried this on h/c cars???
© 2026 MH Sub I, LLC dba Internet Brands
