TSP 5.3L stage 2.5 heads dyno results
My '02 vette LS1 with Kooks LT's, hi-flow cats, Corsa cat back, Halltech stinger intake and MTI X1 cam made 384rwhp.
Added TSP heads, .040 cometic gaskets for 11.18:1 SCR and 8.55:1 DCR. Also added Shanner ported TB and ASP UD pulley. Before and after results below.
Here is a video of the run. Right click & save to target
Originally Posted by JimMueller
Did you need to shim the springs within .050 coil bind, or were they already setup correctly? You've got a PM.
I don't think that you are off that much. I basically have the same setup that you do except for 2 things. I have a little large cam and 1 3/4" American Racing Header. You are only short 7hp and 10tq of what I did. The larger headers are hurting you some on torque and your smaller lift on your cam is where you could be losing hp. I think you have some pretty good gains myself.
LSxGuy widda 9sec Mustang
The heads were built & setup for the guys here @ TSP. They are all set up exactly the same thanks to the cnc seat & guide machine.
The heads ship with 2.023" intake valve height & 2.027" exhaust valve height. As a result we set them up with a .020" thicker shim to keep the spring kit setup correctly
Originally Posted by blazeone
Well, I'm somewhat underwhelmed. My '02 vette LS1 with Kooks LT's, hi-flow cats, Corsa cat back, Halltech stinger intake and MTI X1 cam made 384rwhp.
Numbers do seem low, (specifically the TQ) considering that it looks like you did all your homework with the combo, i.e. quench, static compression, DCR, etc...
I not would say your are off by much though...
Originally Posted by Dr. Jeckel
If I got 40rwhp from heads I would be more than satisfied. I have seen some only gain 20-30rwhp. Your cam only numbers are about 15-20 lower than most cam only cars these days.
Looks like a solid gain
Originally Posted by SideStep
I agree the cam-only numbers started you off short... The gain from heads looks ok....
