Iron 408 numbers are in
Old Sep 5, 2007 | 02:50 PM
Formula_Power's Avatar
Default Iron 408 numbers are in
Here is the list
Iron Block 408 Forged bottom end
ETP 225 heads
244/248 .610/.617 113 cam
42LBS injectors
QTP 1 3/4 headers
TSP True dual x-pipe
ported FAST 90mm Intake &TB
STOCK 4L60e with 4000 stall
Stock Rear with 2.73 gears
Horsepower came in at 487rwhp
an torque a good 462rwtq
I am very happy with outcome and i'm prepared to start breaking things now. so as usual there will be more to come but i am happy now
Old Sep 5, 2007 | 03:39 PM
beardWS6's Avatar
Very nice numbers! Good luck and welcome to the 408 family! Our trannies eat alot of power up, if you would have a 6sp-add another 30-40rwhp!
Old Sep 5, 2007 | 06:56 PM
355sonoma's Avatar
Originally Posted by Formula_Power
Here is the list
ETP 225 heads
42LBS injectors
QTP 1 3/4 headers
I have a similar setup w/ a 6-speed and got 507rwhp 490rwtq. Nice numbers through a stalled auto!!!
Old Sep 5, 2007 | 07:49 PM
the motor was in a m6 before mine and made 509hp so it only lost about 20 hp from going in the auto so i can't be upset with only loosing that much
Old Sep 5, 2007 | 08:30 PM
2001 Pewter WS6's Avatar
Restricted User
With a locked converter, an auto won't lose as much as people would think. Especially with a 10 bolt and 2.73 gears. What was the setup in the other car?
Old Sep 5, 2007 | 09:31 PM
it was a vette with stock t56 with upgraded clutch and stock rear with 3.73s i believe
Old Sep 5, 2007 | 09:37 PM
hey 2001 Pewter WS6 you have a very similar setup as myself except for the 12 bolt and M6....what dyno numbers/track times do you have??
thanks
Dustin
Old Sep 9, 2007 | 04:39 PM
freedom_fighter's Avatar
Brad,
Your PM box is full!!!
Old Sep 9, 2007 | 08:56 PM
got-a-ls1's Avatar
stock 4l60e... how long you think its gonna last? lol
i wanna put a motor like that in my car but then its 12 bolt built trans .. yada yada..
Old Sep 9, 2007 | 11:18 PM
yea no kidding all i am doing now is counting the parts i am going to be replacing
Old Sep 10, 2007 | 11:14 AM
Restricted User
thanks
Dustin
I just swapped cams but I made 500/470 with the same cam you had. I ran ti at the track last year but my TB was only opening 2/3 of the way. The throttle cable was in the wrong hole. It ran 11.0 @ 123 with a 1.52 60'. I had a 4L60e in it then with a 4000 stall. It shifted at 5700 on the 1-2 and the 2-3 since it wasn't at 100% open throttle.
Old Sep 10, 2007 | 05:38 PM
sweet....maybe i can break into the high tens with mmy setup then....if i can lighten it up some
Old Sep 11, 2007 | 10:17 AM
Restricted User
You shouldn't have any problem. My car is heavy. I ran that number with full leather interior, cage and so forth...
Old Sep 11, 2007 | 01:06 PM
4SFEDZ's Avatar
nice numbers dude!
