Are my goals realistic?
400 rwtq
low 12's
with the following setup:
ftra
lid n filter
delphi 85
slp bellow
!air
!egr
tb bypass
nick williams 90 throttle body
fast 90 intake ( unported )
msd wires
ngk plugs tr55's
tsp 5.3 stage 2.5 heads ( stock gasket thickness )
stock rockers ( 1.7 )
custom comp cam 232/238 .595/ .605 112+4
stock bottom end
asp underdrive pulley 25%
pacesetter long tubes
18in bullets
true duels
!cats
3400/ 2.1 stall
pro built tranny 4l60e ( lvl 2 )
alum. d/s
10 bolt w/ motive 3.73's
~tuned for everything by one of the best tuners in the buisness
once i upgrade ill use d/r and i know ill be in the 11's then
im in memphis tennesse, where they just had the shootout, dunno what the elevation is but the weather never seems to be real cooperative esp during the summer times
So I lost 19/23 to the wheels with the beefier driveshaft and 12-bolt, which was a must on both accounts if I wanted peace of mind.
thats also what i believe, thats why i said shooting for low 12's
my car isnt a drag car, its a street car. i want to know on the street what it would run basically. putting on d/r or slicks and running 11.xx or whatever isnt a big deal to me b/c thats not what i run on the street. if id wanted it to be a drag car it would have a 12 bolt or 9 inch with lower gears, better heads, and a way more agressive cam ect..........
if your tires spin obviously you dont go somewhere as fast but when they hook your mph at that location is faster allowing your car to "start"(assuming it hooks at that time) accelerating at a higher mph further back, which is why your trap is higher and your ET is lower.
Typically it works out that street tires are the best example since they dont get the best traction, then DR's, then slicks.
As far as your 10 bolt and auto... ive seen people go low 10's on stock rear with an auto... its not as bad as 6 speeds cause it preloads the rear so it wont snap. plus they have lower gearing so the teeth on the gearing are beefier and less prone to snap. id say throw on some DR's on there and you should be set.
