383 LT1 Hp Estimates
so then realistically you are probably going to dyno HP wise very near to what a bolt-on cc503 car would. the area where the 383 will make a difference would be your torque numbers. you will most likely have higher torque, but HP wise, i'd say about 360rwhp really depending on how well of a port job the heads have, maybe just a tad higher if they are ported decently.
I've read a little here and there. But obviously not enough. The whole build was an absolute nightmare. But I'd be willing to to make a few more purchases to get this thing running at optimum performance. I noticed Loyd Elliot has a "Budget Head"and Cam combo. The heads have an 185 cc intake port and claims it will flow about 255/180 all for around 1100 dollars. Do you think this would be a worthy investment?
I'd get those at least. and did you notice what his heads cam packages are rated at RWHP wise? his first package is like 365-400rwhp, depending on cam, meaning really that 360rwhp is about the highest LT1 RWHP you can pull about. im sure there are special cases but you get my drift.
definitely.
Boost, if I read correctly you are already forged correct?
I think I am making decent power on stock ported heads. My car made 597 with a 19# pulley. I am sure there is more power to be had if I had big $$$ heads, but it works well for me and the car is still 100% streetable.
Yep Its forged. I would love to boost, but dont have the cash. I'm sure the 10bolt wouldnt appreciate that very much either. Who ported your heads? Any Flow #? If at all possible I'm wanting to save a few dollars and just have my heads reworked. But if not I guess I'll be buying a set of heads and larger cam.
and yes your car is a beast nearly 600rwhp and you said 19 lbs of boost?
Just for friendly discussion, if my stock heads weren't ported and I was running my 19# pulley, do you think I would still make the same amount of power? I think my rwhp would drop
