HP / Torque estimates Ok here's what I am putting in the truck over the next few weeks. Just took out the old 5.3 today. It has been a long time (last time I did anything like this to a car the 350 had a distributor and carbs). So not sure what to think on the outcome. 6.0 bored and stroked to 408 317 heads with full port and polish Ferra stainless valves intake enlarged to 2.02 and exhaust enlarged to 1.57 Valves were match ground to the heads - vacum tested each and hold vacum for 30 seconds Upgraded valve springs New GM rockers with trunion upgrade Cam - .588 / .598 115 degrees separation 277/283 duration Double roller timing chain set Upgraded oil pump TBSS intake and TB (intake matched to gasket and mild porting done, TB is ported and polished) 80 lb injectors (holds 60 lbs fuel pressure at WOT) Forged aluminium pistons with -15 cc dish - compression calculated at 9.4:1 Rings set up for boost ATI damper Forged Callies crank Forged Manley Hbeam rods Flowmaster shortie headers and 3 inch pipe through dual series 40 flowmasters Procharger D1SC with pulley to pump 12 lbs at 6000 rpm 4L60E with "Beast" pack, kevlar bands and a few other minor upgrades Hoping for 750 hp at the wheel and 650 ftlbs. Think I will make it? |
Probably closer to 650hp at the tire. |
So what can I change / add? |
Originally Posted by Phil coppney
(Post 19903864)
So what did it make? I gotsa know. |
Sounds like a nice setup. Any updates? |
© 2024 MH Sub I, LLC dba Internet Brands
