LS1 Fbody Procharger P1SC Kit
LS1 Fbody Procharger Complete Kit (Updated)
- Satin P1SC reverse rotation head unit with new input shaft seal and fresh oil (purchased used, some exterior cosmetic/grinding marks from previous installation)
- Aluminum plenum painted black
- Dual 3.5" intercoolers, piping and bypass valve (intercoolers could use new rubber air deflectors)
-Truck kit inlet hat upgrade with 4"
hose and larger air filter
-Brand new Mightymouse Solutions fan shroud painted satin black with brand new Spal 16" fan and low mileage 9" fan with pigtails so no splicing into car wiring necessary
- Brand new ATI J-bracket, studs, idler pulley, axle, standoffs and spacer
- Brand New ATI 6 rib crank pulley with dowel pins and modified crank bolt
- Brand new 3.7" Procharger pulley
- Brand new ATI upper radiator shroud
- Brand new crank pinning tool and kit
- Brand new belt
- Brand new check valve, breather filter and tubing for PCV
- Brand new GM 2 bar MAP sensor
Sold!!!
