00'SS,Th400,Cam/Nitrous Car 00'SS,Th400,Cam/Nitrous Car -------------------------------------------------------------------------------- $8,000 BRO Mods are: SLP LId Ported TB Non Cruise Throttle Cable SLP Bellow's Proffesionally Painted LS6 Intake New OE Water Pump/160 T-Stat OE Belt Tensioner Powerbond 25% Pulley 232/238 .595"/.605" Patriot Extreme Gold Srings/Seals LS2 Timing Set Chromoloy 7.4 Pushrods Ported/Shimmed Oil Pump DynoTune Wet Kit{upgraded noids} DynoTune Window Switch DynoTune Bottle Heater HSW Standalone Fuel System Dual 10lb Bottles{Chasis Engineering Bracket} Pacesetter 3" ORY SLP Dual/Dual RMVB TH400 SJM ABS Delete/Line Lock TCI Flexplate PTC 10" 4200 Stall Hurst Pistol Grip Quarter Stick B&M Tranny Coller/6an Braided Lines RCI Tanny Blancket Aluminum DS Lakewood Drive Shaft Loop 10 Bolt 3.73's LPW Cover/Axle Braces(starting to whine alittle) Sphon Adj. LCA/Adj. Panhard Bar 325/45/17 M&H Dragradials Wolfe 5 Bolt'n RollBar RCI 5 Point Harness Things Removed,Front Bumper Support,A/C,Rear Seats,Front Sway Bar,Washer Res,Cruise Control,I have all these parts to include Awsome for someone looking to run a 11.5 Class or a Bracket Race and do some car shows and cruizes http://vids.myspace.com/index.cfm?fu...deoid=39172420 BTLFEDSS |
Sombody's got to be interested? BTLFEDSS |
how big of a shot did you put on it ?? Stock motor ?? |
I might be interested. Just got to figure out if the setup will work out $$ wise for what I want to do.If you drop the price definitely shoot me a call. |
| All times are GMT -5. The time now is 01:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
