Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Ls1 Rx7 Complete W/ help from 02NavyBlueZ
Old 09-12-2010, 10:34 AM
  #61
sciff5's Avatar
Originally Posted by Nextinstant39
Its a Tick Stage 2 rebuilt trans, Aluminum drive shaft and then a stock FD rear end. I plan to do a Cobra IRS this winter along with a major overhaul of the rest of the suspension.
I think this car will come in lighter than that since it doesnt have any heat or A/C components including the core under the dash. The Abs system has been removed along with all the wiring. Wipers with motor are gone and the car was converted to manual steering also. Pretty much anything that wasnt needed was taken out. I think i saved about 50 lbs just in all the wiring that was taken out, lol.
My last FD weighed 2660 on stock twins and still had everything listed above. It was also a rotary though, so this car might be closer to that number.
-Austin
I think you're going to be dissapointed. The FDs are lighter than FCs but my FC is stripped and it still weighs 2800lbs.
Old 09-12-2010, 12:08 PM
  #62
Nextinstant39's Avatar
For anyone that was curious, the car weighed in at 2640 with full interior and a 4 point cage. Without the cage it would probably be about 2580, but im more than happy where it is at 2640.
-Austin
^ you must have missed this post. I weighed the car about a month ago at 2640.
-Austin
Old 09-12-2010, 01:19 PM
  #63
sciff5's Avatar
-Austin
Did miss that. That must feel good. I am surprised to find out how much lighter the FDs really are than the FCs
Old 09-12-2010, 02:52 PM
  #64
02NavyBlueZ's Avatar
Just got it home. Having a weird issue. The temp is normal while driving(about 190 degrees), but when i stop at a light and the car is idling it wants to heat up(about 220). Once i start driving again it drops like a rock. I never had an issue like this before the swap. My temp sensor for my gauge is at the back of the passenger head. Maybe its still working all the air bubbles out of the system? Its a brand new water pump and 180 degree thermostat too.
-Austin
Austin,
I wouldnt worry about the temp issue too much until you get it tuned as long as you got the air out of the system I'd be willing to bet a tune will cure a lot of your problems. Right now your running lean with the new heads/cam and until you get the tune to add the needed fuel to correct your A/F ratio it will run a bit hotter. Your also idling around 1200rpm so its going to run a bit hotter when stopped also. I would get it tuned and take it from there.
Old 09-12-2010, 04:39 PM
  #65
944V8inMD's Avatar
ALRIGHT!!! we need to have a swapped car meet here in MD once i finish resealing my motor! holy crap that's a gorgeous swap man!
Old 09-12-2010, 09:39 PM
  #66
itsslow98's Avatar
-Austin
Kinda makes me feel bad thinking that your car weighs 1300 pounds less then mine lol.
Old 09-15-2010, 05:05 PM
  #67
Monday is the tuning date. Should be a fun ride home from Wilmington =)
-Austin
Old 09-24-2010, 12:11 PM
  #68
NOTFAST's Avatar
-Austin
Soooooooo?
Old 09-25-2010, 07:53 AM
  #69
Y2KFirehawk's Avatar
Originally Posted by NOTFAST
Soooooooo?
Seriously!
Old 09-25-2010, 08:07 AM
  #70
I ended up having the car street tuned so no dyno numbers. The car is fast as F*** tho =)
-Austin
Old 09-28-2010, 06:50 AM
  #71
Here is a little clip of the car from down at the beach this past weekend. One of the Vdub guys there for H2o took it.
http://www.youtube.com/watch?v=-S5rgN04MQ8
Old 10-04-2010, 12:51 PM
  #72
liqidvenom's Avatar
what a small world. I was there sitting on the island on the left of the video. and i watched your car leave. sounded nice. my V was parked in the lot if you managed to see it.
Old 10-05-2010, 06:31 PM
  #73
too funny, it is a small world. I remember seeing ur V there.
-Austin
Old 10-07-2010, 08:59 PM
  #74
Another video my friend put together from our weekend at the beach. The end has some races with my car.
-Austin
http://www.youtube.com/watch?v=b53MGla7Gvk
Old 01-18-2016, 02:13 PM
  #75
bigrigwrecker's Avatar
I really dig the intake, wheres it from and is it EO?
Quick Reply: Ls1 Rx7 Complete W/ help from 02NavyBlueZ
