OEM C4 Zr1s local? Need to test fit
Long story short I just upgraded to CTS-V brakes on my Camaro and my aftermarket Zr1 wheels no longer fit, even with 1/2" spacer. I was told by the person who had successfully fit cts-v brakes under his zr1s that his are OEM and thats the difference. I would like to find someone local that wouldnt mind letting me throw one of their OEM zr1s on my car to see if it fits.
Thanks in advance.
Thanks in advance.
What CTS-v brakes? 6 or 4 piston? What size rotors? I am running 4 piston CTS-v calipers with 13.5" Vette Z-51 rotors. But this is on some custom modded stock spindles on my S-10. The wheels are Vette ZR-1's, 17x9 fronts. But with the Vette offsets and the S-10 setup, I needed to run a 2.5" spacer to ge the wheels to sit flush with the body. The spacers are only being used to set the wheels in the right spot, not to clear the brakes.
Thanks for the reply. I gave up on the zr1 wheels fitting, though. There is not a chance that theyd come close to fitting with anything smaller than a 3/4" spacer.
