Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
lean?
Old Jun 8, 2005 | 07:43 AM
RealQuick's Avatar
Originally Posted by firechicken2k
You assume too much.
I actually didn't go WOT even once, since about beginning of May. I sorta miss it. Cat went bad, spark plug wire was severed, etc.. new problem each day. This time my tranny (in my opinion) runs too hot on the street. Around 220* according to my gauge.. So I wont be able to go WOT again, until I get a fan for the tranny cooler and may be a deeper trans pan. But at least Ill be able to go WOT while my tranny is cold and highways! Finally.. at least some type of action..
The car, aside from the dyno day, has not seen more than 4000 rpms in a long while.. and thats with my 3600 stall..
Stop assuming.
Thanks.
If you expect people to answer you questions then you must give details. Assumptions need to be made. Either way, assumptions don’t change anything I said. Seems like you have a ton of problems with your car, good luck getting them worked out.
