Inspection time for me. NH help please
Ok, I need to know what codes I should delete to pass inspection in NH. I have been throwing some MAF codes lately so i put it into SP mode. I am showing P0102 and P0103 right now. How do I make sure I am getting no codes when I get there next week? I use HPtuners
LS1Tech Sponsor
Originally Posted by ace68
I know that when you run SD you need to set p0102 & p0103 to no mil but I don't think a SD tune will pass inspection.
Thats good too know, I though everyone had to test obdII. The place I go to the state inspect jumped up $25 from the previous year. I miss the good old days ,I had a friend in mass get my emissions off the towns police cruiser.Ahh the 80s were good times.
Originally Posted by Slowhawk
Thats right,if the truck get';s the OBD2 plug in test it will fail with those codes and it will fail if you delete the codes because the system will show a fail safe.
hmmm, so how do i get around this? i can't figure out why i keep getting a P0102 with the maf plugged in.
Originally Posted by JL ws-6
Is the maf dirty?
LS1TECH Sponsor
start with the basics heres a few things from gms book on what can set the code
Inspect for the following conditions:
• A misrouted harness. Inspect the MAF sensor harness in order to ensure that the harness is not routed too closely to the following components:
- The secondary ignition wires or coils
- Any solenoids
- Any relays
- Any motors
• A low minimum air rate may cause this DTC to set during deceleration. Inspect for the following conditions:
- A plugged intake air duct or a dirty air filter element
- Any objects blocking the air inlet screen of the MAF sensor
- Any throttle bore or throttle plate coking
• A wide open throttle (WOT) acceleration from a stop should cause the mass air flow display on a scan tool to increase from about 4-7 gm/s at idle to about 100 gm/s or more at the time of the 1-2 shift. If not, inspect for a restriction.
• Any unmetered air entering the engine may cause this DTC to set. Inspect for vacuum leaks in the following components:
- The intake manifold
- The throttle body
- The exhaust gas recirculator (EGR) valve flange and pipe
- The MAF sensor seal
- The maifold absolute pressure (MAP) sensor seal
- The EVAP canister purge valve seal
- The fuel meter body seal
- The brake booster system
- The air induction system
- The crankcase ventilation system
- Any solenoids
- Any relays
- Any motors
- The throttle body
i didn't change a thing. I put a ported tb on, it ran like ***. i had some audio/wiring work done, put the stock tb back on, started getting codes. not sure if the code is due to changing the tb or due to the wiring work or neither, but, the computer settings havent changed.
with the maf turned on, i get the code when i give it more than half throttle. SES light comes on. I logged with HPtuners and at 70% throttle the truck fell on it's face and started bucking. maf read 60.xx then 0. looked like this on the graph \/\/\/\/\/\/\//\/\/\/\\/\/\/\/\// lol
did the maf hit 0 when the tps went 0
no, it reads 1g ish at 0 tps
I don't think the meth could have any effect because it is nowhere near the maf and has never been a problem before.
