TTP Stage 3 AFR 205cc Heads - Package Available Discounted
I have had numerous calls about our Stage 3 AFR 205cc TTP finish port/polished heads/cam packages. I finally have 205 heads in stock and ready to bolt-on. We have one set finished port/polished that were tested for less than .5 miles and then customer decided to step up the cubes and go to 225cc heads...
TTP Stage 3 Equalizer Heads/Cam Package
# TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish
# Ported/Polished by TTP
# TTP Equalizer V.3 Camshaft
# TTP Hardened Chromoly Pushrods
# Rollmaster Double Roller Timing Chain
# SVO 30lb Injectors
* GM OEM Lifters
# GM Steel Headgasket Kit
# (2x) GM Headbolt Kits
# (2x) AIR Gaskets
# (1x) EGR Gasket (If needed)
# GM Timing Cover Seal
# GM Timing Cover Gasket
# (2x) GM Waterpump Gaskets
# Installation
# LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$6250.00 Turn-Key (Add $100 for Corvettes)
That is the normal price. I can do this package for a discount of $800 using these 205 heads. If you want brand new heads, I also have those in stock. So final price out the door would be $5450.00 turn-key.
* GM OEM Lifters
# (2x) AIR Gaskets
# Installation
lol, if i had a stock car and was looking for a h/c package i'd deffinitly go with you guys. to bad i dont i could only wish my h/c package was something like that.
anyway, another bump for you.
