Philly, Looking for a shop to install heads/cam/tune
Yeah just like the title says.
I have a 2002 LS1 in my Nissan. I pulled the 241 heads and I am not sure if I want to use them or not. I have a classified up trying to trade a very low mile set of complete 317 heads for 243's. But regardless I am going with a Thunder Racing Cam package with dual springs.
So whatever heads I use 241 or 243 will be milled, and machined, and re-assembled. I am an electronics guy, so when it comes to internals of an engine my skills lack. But I am looking for a shop that won’t rape me too bad.
Install new cam, new lifters, new oil pump, push rods, heads, and water pump. Basically head and cam swap with reassemble.
If you have a shop near me (19135) please let me know, and if there’s any way you can shoot me a rough number that would be awesome.
Kevin
Kevin
Agreed on Rapid Motorsports. A buddy of mine got his '02 Z28 tuned by the owner of Rapid and he did a hell of a job. Free mods, SLP lid, smooth bellows, and Pacesetter LTs dumping after the Y pipe and Mikey was able to squeeze out 368hp/376tq.
I just sent them an email with all the cam info and to see what the labor rates would be. The only thing is that Birdsboro is about 60 miles each way.
Right now my car is open header. But the rear 02 sensors are turned off. And I am using modified hooker headers, true dual, no cats, that are going to be going into dual Borla XR's 3/3.
That intake is homemade, but I need to make some corrections to it. I want to bring the MAF closer.
Does rapid ECU tune, because I have 5 codes, and only one is real. The ecu is looking for my AC clutch relay, my fuel sending unit, and another fuel relay, and some other false code. The only real code I have is MAF under voltage which I need to figure out why.
The cam specs are
"TR 220-112" - 220/220 .551/.551 112 LSA
Id be curious to know what it can do, but the car is less then 2400lbs
The cam specs are
Frans website is http://www.raceprovenmotorsports.net/ . He will hook you up and is very close to philly.
Trust me when I say that Rapid is worth the drive. He's about 75 or 80 miles from my house, but I'm glad I went.
Mikey does his own tuning. He is one of the best LSX tuners out there. Some other shops in the area sub-contract out their tuning.
The cam specs are
The cam specs are
Harris speedworks- 10- 20 minutes away.... they did my car and nothing but good things to say about them
http://www.harrisspeedworks.com
Thanks for the input, I'm gonna have to call around and see whats doing.
But if any of you boosters need a pair of 317's I have a set with less then 6K on them. Will sell or trade.
And pics for those that care to see...
The rust has been fixed
we're located right off Street Rd in warminster. do all our own tuning and installs and have an inhouse dyno. give us a call and we can work something out for you...215-674-5924....i promise you wont be dissapointed. either way, goodluck with that project, looks very promising!! i live in the NE, hope to see it cruising around when your all done. be on the look out for a Red Ws.6 with black rims.
Rick
Rick
that's a cool swap, i wanna see some times from it when it's done. can't weigh much so if it'll hook your in business.
not to go off topic but what trans? or if you want pm me some specs on it wnen you get time im interested
