1987 chevy 350 rx7 car is a 1987 RX-7 with a Chevy 350 engine and a 700R4 transmission. Engine: Chevy 350 4 bolt with 8.5:1 compression, .30 over pistons with slight dish, steel shim head gaskets, Powermax Crane Cams with matched valve springs, 461 camel back heads with 1.94" and 1.5" valves, 1.6 roller rockers, hardened push rods with guide plates, Edelbrock Air Gap RPM intake manifold, Holley 650 vac secondary with electric choke, moroso alum crank and water pump pulleys. Water pump is new with under 500 miles. Engine was rebuilt approx. 7000 miles ago. Tranny: 700r4 with corette governor, 3-4 wot up shift valve, 1800 rpm stall, shifts at 5000 rpm at full throttle (still has lock up but not electric). Transmission was rebuilt in 2000 and freshened two years ago. Ignition is MSD 6A firing an Accel super coil to MSD distributor. Swap was done with the Granny's speed shop kit with jeep headers. Has a custom driveshaft to a LSD rear end with 4.10 gears. Car has a brand new Holley electric fuel pump. Radiator is new and from 1985 Monte Carlo SS with a short style pump and a Flex-a-lite black magic fan. Suspension is from Ground Control, has 4 way adj front KYB AGX struts and 8 way adj rear KYB AGX shocks. Has caster camber plates in front and poly bushings throughout. Has adjustable coil overs at all corners and 1.125" sway bar. Has had a 5-lug swap done and has the larger brake setup. Car is dark red with gray interior and leather seats are in great shape. Needs new interior door panels for manual crank windows. Driver's side has 5 point harness but would recommend installing 3 point belts (included with sale). Car has tilt wheel, manual doors/windows, 5% tint, Sunpro tach and Nordskog speedometer (speedometer needs to be hooked up). All switches work in the car except sunroof but replacement parts are included. Car has S5 mirrors, wing, and taillights. Has cowl induction hood to clear air filter. Windshield has a crack but it does not leak. The car has some rust but most is only surface rust. The wheels are 15" american racing wheels with Kuhmo tires in good shape. car is fun to drive and will probably run a high 12 in the 1/4 mile. i am pretty sure that the tranny needs a new kickdown cable or this one tightened up a bit but other than that is awesome! asking $3500 obo |
cool car. I have a friend interested in doing a 350 swap into some toyota. i'll send him the link and see if he'd be interested in buying it. |
© 2024 MH Sub I, LLC dba Internet Brands
