Stay A4 or go M6?
#65
um what point the converter will flash to on a launch or stomping it 4000 will slip up to 4000rpm its kinda like slipping the clutch up to it get you in motion a lot quicker than leaving around 1700 or so what the stock converter is
#66
need for diffrent stalls are depending on what cam you use if you have a cam thats powerband is from 3500-7000 you would want a stall that is atleast 3500 stall it helps you leave in the powerband
