Best budget head for boosted 408? I know everyone runs the 317 castings but I am in the process of trying to get everything together so I can start building my engine. I am new to forced induction so I don't know much but I have been thinking about either going with the 317 heads, ls6 heads, or maybe even the l92 heads. The motor is going to be 9.5.1cr with a f1a blower running somewhere in teh 14 to 16lbs of boost range and hoping for 750 to 850 power. I know a thicker deck is my friend with boost but I don't want to spend 2500k plus on heads right now. Thanks for any help and tips you guys might have. |
1650.00 will get you as cast TF heads. They flow over 300 @ .600 as cast. those are the best for the money. |
I run Dart 225's ported to the max with my 408 |
WCCH 317's here |
afr225's here |
Since you were asking for a good inexpensive head, take a look at the Patriot LQ9 Stage 3 heads. $1,285.00 and they do the job quite nicely for what you pay for. Check out this build where we reused the Patriot Stage 2 heads from the customer's old 346 on his new LS2/402. http://www.exoticperformanceplus.com...Car.php?car=40 Bob |
I posted the same reply in another thread:
Originally Posted by Beaflag VonRathburg
(Post 10364682)
If you search on Ebay you'll find a guy who sells bare All Pro castings for $700 including guides. They're as cast, but you can have them finished for $150 to have the guides installed and $180-200 for a good valve job. You'll need springs and valves, but you can get valves for $240 and springs for $250. You'll have a 230cc after market casting with a thick deck, solid rocker pad, 1/2 inch pushrod holes, etc... for $1600. That's about the same as you'd be able to get a set of stock ported castings for. |
I am going to see how Dart 225s do with my turbo 408 project |
My Old heads were 317 casting Patriot heads.... they were $1000.. had them gone thru when the 370 was last rebuilt...... Made 1100rwhp that way with an S88....... I dont see a problem with 750-800 |
Originally Posted by NA$TY-TA
(Post 10409032)
Originally Posted by OUTLAWZ RACING
(Post 10409849)
Jesues what head studs did you use. I have the same heads but mine where just out the box nothing done to them. I would love to see another 60 hp out my combo but im afraid to push water did u have a issue with that? Pm me :hijack: Out the Box ARP Head studs. I could run all day at 20 psi and nothing.... on good fuel of course. When we went beyound that i would start to push water. At 22+ i would start to push a lil water even on the dyno. The 1132rwhp pull we had dripping from the back of the heads some... Shawn @ VA Speed is doing a few things to the new heads and motor. Ill be sure to post up when its done. Kyle |
Out of the box L92 heads. We saw 24psi for a split second this past weekend (22 most of the run). Its got the L19 ARP studs on it. It went nearly 130mph in the 1/8th. Once I get more timing put in it at the bottom it'll go alot quicker (and faster too). Not even 1 single drop of water in the overflow. |
(Post 10410511)
Originally Posted by veee8
(Post 10412077)
When it pushes that water, do you let it cool down and all is good? Do you re-torque or have to change the gaskets at that point? I know the SBF's would push water, and then seal themselves back up, does the LS 4bolts do the same? |
Hard to go wrong with the L92 heads. Flow great out of the box and are pretty cheap to boot. |
If you can get aftermarket casting for 1650 that flow really really good its a no brainer to me. Go Trick Flow. If your gonna swap heads there is no reason anymore to put on factory castings even if you are on a budget. |
out of the box l92 heads with upgrades springs...saw 615rwhp on 5psi on my 402...not too bad for a set of heads that cost me $800. |
Jeez man, only $800 for a complete set and pulling that kind of rwhp @ only 5psi? My #317's flow 321CFM @ .600, so I should be in for a real treat! I don't plan to boost past 20psi either, so I should be okay with pushing water, we'll see! |
© 2024 MH Sub I, LLC dba Internet Brands
