Ok aps guys with speed density what size silicone to eliminate the maf?
LS1Tech Sponsor
Just replace the MAF with a pipe the same size the MAF was. Then you have options for later use as well. For example you could weld or drill/tap into the pipe for a meth nozzel and be spraying right after the intercooler/before TB.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
Yep, thats exactly what i did with my set-up... replaced the MAF with a pipe and welded a bung on it for meth
__________________
Actually think you can spray both..I am going to have the alc injection likely AIS stage 2 just wondering if anyone has mounted it on drivers side rear. I want to keep my t top storage and have big sub box on rear deck and am putting the nitrous on passenger side where spare tire is so need to mount the ais under the hood or in the back and like the back better much bigger tank.
