Best heads for Turbo ls1?
Old 11-18-2008, 05:35 AM
ohplz's Avatar
Default Best heads for Turbo ls1?
what heads u recomend on a forged 5.7 setup with a turbo?
317's ported and polished? ( been lookin for them and hard to find )
Old 11-18-2008, 05:50 AM
EPP
EPP's Avatar
I would go with AFR 225 heads. These heads have a thicker deck surface will helps to keep the head gaskets in place on higher boosted engines. Bob
Old 11-18-2008, 08:12 AM
98Z28MASS's Avatar
You can pick the 317's (also known as 6.0 liter heads) from Patriot Performance. Also, if your on a strict budget you could run a set of stock 317's with upgraded springs and retainers and that should work pretty well too. If you have a slightly larger budget and want a great head then the afr 225's that Bob mentioned above are a really good choice as are the TFS heads. How much power/boost are you looking to run?
Old 11-18-2008, 08:23 AM
OUTLAWZ RACING's Avatar
I use out the box patriot stg3 317 heads.
Old 11-18-2008, 08:57 AM
Firechikn's Avatar
The best and 317's in the same sentance. haha. Decent for a budget but def. not the best. After market heads have thicker deck like Bob said, and def. flow better. Depends on your budget.
Old 11-18-2008, 09:00 AM
98Z28MASS's Avatar
Hahaha +1, there are far better FI heads out there than 317's but for most budget builds under 800 hp they will do the job. I agree though the thicker deck of the AFR, TFS, ETP heads are the best choice but it really depends on the OP's budget.
Old 11-18-2008, 09:05 AM
El_Diablo's Avatar
I'm going for broke. ETP's are a work of friggin art.
Old 11-18-2008, 10:31 AM
MY99TAWS6's Avatar
Actually think the AFR 205s might be even better on the smaller engine and for general street use. I went AFR 225 but have a 408 and might even go bigger engine later.
Old 11-18-2008, 11:14 AM
valiant65's Avatar
There are some examples of running stock head castings and make over 1000 hp so the thicker deck isn't always a necessity. I think it is more of a decision between paying for bolt-on parts or special machining.
Old 11-18-2008, 11:39 AM
1320's Avatar
I like 317's.....for the money. I have several in the 600-800 rwhp area. I would agree that they become an issue though in that area. A good ported 317 flows around 310 cfm, although some flow more. L92's.....nobody talks about l92's....I like em. Afr 225's are nice, but deffinately show in the price.
Old 11-18-2008, 12:15 PM
67Firebird455's Avatar
I'm gonna rock my 317's, they flow 321cfm, see how far they'll take me on the 408. I plan to only run somewhere around 15psi anyway, don't need to get TOO greedy. The AFR 225's are a bit costly!
Old 11-18-2008, 12:18 PM
LS1Tech Sponsor
hellbents10's Avatar
Right up to 1000 the 317's are ok with good fuel.
Old 11-18-2008, 12:56 PM
camaroandreas's Avatar
I have 1200hp with stock 853 heads. It can be good to have less flow so the turbo hits the right place in the compressormap. I run 30-35 boost with my S480 turbo. And that is a good boost range for that turbo. If i had better flowing heads i might get less hp because my turbo doesnīt flow so well at 20 psi boost.
Old 11-18-2008, 01:05 PM
MY99TAWS6's Avatar
Actually you should be able to get same power as before at less boost or more total power. more powerful and better flowing the engine is NA better it will be on boost.
And better off boost. And man you are pushing a lot of boost thru aren't you. That is how much I put thru my dsms!
Old 11-18-2008, 01:17 PM
You have wrong. A S480 canīt flow 1200hp at 20-25 psi boost. With better flowing heads the turbo would be empty at 20-25 psi at ~ 1000 hp if you look at the compressor diagram.
Old 11-18-2008, 01:50 PM
MY99TAWS6's Avatar
My experience with turbo maps is they are all fine in theory. In the real world not always work out like the maps.
So you are saying with better heads you can't hit your 120 pound per minute max airflow at all. First time I have ever heard better flowing heads being a negative. News to me. All the dsm guys that run big power run very expensive fully done ported and big valved heads ,not one of the big boys run the smaller flowing heads just so they can get some compressor map theory to work . From my real experience you will just see max power at lower boost. But your theory sounds interesting. I guess I better sell off my prettty afr 225s and put on some factory ls1 stockers now. NOT!
And you are saying you need 35psi to get to 1200 rwhp with your ls1? Isn't that sort of proving my point? A built 427 with top of line heads could likely get 1200 easily with a big snail at 20psi. Maybe time to rethink that combo? Why the need to go to such high boost levels its not a 2.0 litre like my dsm.
How the hell do you keep head gaskets in the engine?
Old 11-18-2008, 03:52 PM
I build engines and dyno tune them all day long. And i have seen this several times. If you want to max out the turbo you must hit the compressor map right.
I use our pyramidring gasket kit we have developed, we use them on all bmw engines we build as well. No head gasket problems at all.
My engine has 1000 ft/lbs torque at 3600 rpm and still have 1200 hp at 6000-7000 rpm, so it was a successful combo. I ran 8.53 with only 17 psi . Just waiting on the snow to disappear
Old 11-18-2008, 04:05 PM
LS1Tech Sponsor
Whats better for a N/A engine is better for a turbo engine. Better cylinder heads will show better power to an extent.
Old 11-18-2008, 04:08 PM
Not if you loose boost at higher rpm (outside the compressor diagram).
What has Drturbo to say about this?
Old 11-18-2008, 05:08 PM
98Camarod's Avatar
Curious to see other opinions. I thought better flowing heads n/a would be better for FI myself.
Quick Reply: Best heads for Turbo ls1?
