EPP's Cog Drive Assembly for F Body ProCharger now available!
Old 01-23-2009, 04:49 AM
EPP
EPP's Avatar
Thumbs up EPP's Cog Drive Assembly for F Body ProCharger now available!
EPP's Cog Drive Assembly for F Body ProCharger is now available! http://www.exoticperformanceplus.com...html?item=1749
* No more belt slippage! Our cog drive system will give you consistent boost, run after run.
* You will see more boost with our cog drive system, as serpentine belts usually slip to some extent.
* Belt tension does not have to be nearly as tight as it does with a serpentine belt.
* Our blower bracket reinforcements keep the bracket from flexing.
* Our system is designed for maximum impeller speed using an F-1A at 7000 rpm.
* Requires use of an ATI Performance Products harmonic balancer, the same one that is used for the 8 rib serpentine system.
* The top brace cannot be used with power steering, and we have not yet tried using our cog drive system without the top brace.
* Our cog drive system is recommended only for use with automatic transmissions. Use with manual transmissions will likely destroy the cog belt.
* Bottom radiator mount may need to be moved forward to allow added clearance, as the blower will stick further forward.
* We have extensively tested our cog drive system with our Camaro, with it's Powerglide and 5000 stall converter. We entered a wheelstand competition where we had to pedal the car, and the cog belt still looks great.
We have tested this combination our my '99 Camaro with it's powerglide and high stall, and have had no problems with the belt. We do not recommend this assembly for manual transmissions.
All of the fasteners will be stainless steel on our production kits. Our initial pricing on the cog drive kit will be $1050.00 plus shipping. The blower does not come with the kit.
More pic's can be seen at the bottom of the following link. Thanks. Bob
http://www.exoticperformanceplus.com...Car.php?car=12
Old 01-23-2009, 07:00 AM
BLNLS1/RX7's Avatar
Thats a very good price Bob.
Old 01-23-2009, 07:45 AM
dopy's Avatar
Looks great. now I wish I had a auto
Old 01-23-2009, 08:58 AM
Frost's Avatar
NICE WORK!!
That thing looks sweet!
Old 01-23-2009, 10:34 AM
LilJayV10's Avatar
I know someone will ask so it might as well be me. Why shouldn't it be used on manual cars?
Sweet looking part.
Old 01-23-2009, 01:24 PM
turbo'd stang's Avatar
Nice work...
Old 01-23-2009, 01:55 PM
frcefed98's Avatar
Excellent price on the cog set up!
Do you think the shock from a manually shifted TH400 will be too much for the cog belt to take? This TH400 shifts hard as hell
Might be going back to a procharger this season....
Old 01-23-2009, 02:47 PM
Rickys S/C Z28's Avatar
looks very good Bob. I take it that this would Not be good for the street?
Old 01-23-2009, 03:08 PM
RAACCR's Avatar
Sweet looking part.
Pulley would need to be built with an overrun clutch for cog belt with manual trans.
Old 01-23-2009, 03:10 PM
Dark Shadow's Avatar
i was on your site and it said something about not able to work on power steering. has that been corrected? i deff would buy one.
Old 01-23-2009, 03:22 PM
LS1Tech Sponsor
hellbents10's Avatar
Awesome!!!
Old 01-23-2009, 03:35 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Nice. Now when is the C5 version going to be ready
Old 01-23-2009, 04:09 PM
EPP
EPP's Avatar
Here is a link to it in our shopping cart. Bob
Old 01-23-2009, 04:10 PM
EPP
EPP's Avatar
Thanks Steve!
Thanks! Auto's are the way to go for drag racing, at least in my opinion.
Originally Posted by Frost
NICE WORK!!
Thanks, we appreciate it!
Sweet looking part.
Too much shock on a cog belt will destroy the teeth. Manual transmissions are just too harsh on a cog belt.
Originally Posted by turbo'd stang
Nice work...
Thanks!
Is it priced too low? lol
As long as you have a loose converter I don't see it being a problem. We used this set-up when we entered the wheelstand contest, and the car was extensively pedaled, then when it stood up on the rear parachute mount and rotated towards the guardrail, it was slammed down to Earth to keep it off the guardrail. The belt was just fine, and is still good to use.
Thanks Ricky. If you had a loose converter it may be okay. We haven't tried it for normal street use, it would be a good experiment to do.
Yeah, ATI Performance Products Superdampner should do the job.
The top brace would be in the way for the power steering pump. We haven't tried this set-up without the top brace, so we don't know if it would cause a problem without it. I'm sure something could be done to modify it to work with power steering, sooner or later we'll have a car in here with power steering to try to make it work.
Originally Posted by hellbents10
Awesome!!!
Thanks, we appreciate the feedback.
With Hormilla Engineering's (Cartec) excellent Flip Drive for the C5/C6, all you need to do to convert it to a cog drive is to swap out the crank and blower pulleys to cog pulleys. They did a great job with their design. Bob
Old 01-23-2009, 04:24 PM
Alan King's Avatar
Talking Awesome
I just talked to Bob a couple of hours ago and ordered this awesome kit. Can't wait to get it and install it. Thank you EPP for coming up with a solution to the belt slippage problem.
Old 01-23-2009, 04:35 PM
TS6
TS6's Avatar
I'll let you have my car to do a power steering compatible kit if you give me one for free.....please?
Old 01-23-2009, 05:53 PM
BLNLS1/RX7's Avatar
Bob,Have you applied for a patient yet?
Old 01-23-2009, 06:29 PM
SSilverSSurfer's Avatar
holy **** none of the tires are touching the floor bad ***
Old 01-23-2009, 07:01 PM
TS6
TS6's Avatar
Is Bob a doctor?
Old 01-23-2009, 08:33 PM
Customizing Director
MadIceV8's Avatar
Nice setup. Belt slip should no longer be a problem
Quick Reply: EPP's Cog Drive Assembly for F Body ProCharger now available!
