twin 94's Well my new Precision Pro Mod 94's showed up today-i figured i would share some pics with you guys.They just released these at the PRI show in Dec. They feature billet compressor wheels,and lightweight v band turbing housings. Rated at 1850hp each,what do you think these babies are gonna do on my new 672cid bbc?:devil: http://i256.photobucket.com/albums/h...ures94s001.jpg http://i256.photobucket.com/albums/h...ures94s002.jpg http://i256.photobucket.com/albums/h...ures94s003.jpg http://i256.photobucket.com/albums/h...ures94s004.jpg |
Nice I bet they are pretty light with the v-band turbine housings too! How much 50lbs or less. |
it'll be a turd :jest: |
Very nice. Why does Precision cast the compressor housings with the slots around the inlet vs a smooth inlet? |
It's a ported shroud housing, they use it to keep surge down but it's probably a non issue on these engines. BTW these things are pretty freakin light.
Originally Posted by onfire
(Post 10985253)
If you need a 2nd set of fabrication hands let me know. I'm proficient with the tig. |
you should let me have them for free... |
What size in the v-band turbine housing? |
Originally Posted by hellbents10
(Post 10985144)
Originally Posted by Fireball
(Post 10985173)
Originally Posted by Phil99vette
(Post 10985314)
Originally Posted by Tainted
(Post 10985370)
Originally Posted by veee8
(Post 10985403)
Do they have the v band housings in a .96ar with a 88mm wheel? |
Very nice! |
hey phil...I think you need a set of those for your ride :devil: |
(Post 10985619)
What is this going in? Looks killer! :devil: |
Originally Posted by Shawn @ VA Speed
(Post 10985108)
Rated at 1850hp each,what do you think these babies are gonna do on my new 672cid bbc?:devil: |
Wow!!! I don't my engine could push one of those... That's insane.. You should be at like 2500rwhp+ if you lean on them.. I can't imagine... |
Originally Posted by 98turbls1
(Post 10986153)
Wow!!! I don't my engine could push one of those... That's insane.. You should be at like 2500rwhp+ if you lean on them.. I can't imagine... I'm thinking closer to 3200 to the tires! 2400 can be had with a set of gt47's in the right combo |
Those are insane. I haven't ever seen a turbo with a V band turbine housing. Is it relative to a T4 or T6 flange. |
Originally Posted by Beaflag VonRathburg
(Post 10986366)
(Post 10985619)
| All times are GMT -5. The time now is 12:25 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
