A2W intercooler? any gain over A2A? anyone ran a ebay one?
Which car? Do you have a lot of boost on tap you are currently not running? An A2W really shines for drag if you have a water tank you can keep filled with ice and keep your IATs sub-ambient. Big boost, less chance of detonation.
Jim
Jim
I got my A2W off of ebay for pretty cheap, I think for around $250, like 2 years ago. It's one from a twin turbo c5 corvette. You'll still be able to run an A2W on the street without any problems, granted you have a heat exchanger and good pump to move the water, you just won't see the super cold IAT's that you would packing it with ice at the track. If weights a factor in your car, it might not be for you, because it does add alot more weight with the A2W setup. I've got a 5 gallon tank in the spare tire area, the big intercooler sitting up front, plus the pump, lines and a heat exchanger. The A2A is simpler, cheaper, and lighter. They've both got there pro's and cons, I guess.
How is the quality of the ebay stuff? Got any pics? We were thinking about a A2W kit off there.
https://ls1tech.com/forums/forced-in...uild-pics.html
they're not very good but thats all i have, hope it helps
