just bought a pro charger d-1sc
Old 04-14-2009, 10:33 PM
408>>98transam's Avatar
Default just bought a pro charger d-1sc
i have a 1998 trans am with a 408 with a m6 and 373s bought the pro charger through EPP cant wait to see how it runs! any opinions welcome!!! it made 440 at the wheels before !!!!
Old 04-14-2009, 10:39 PM
DanWS6's Avatar
You're going to love it.
Old 04-14-2009, 10:48 PM
it ran 117.7mph at track curious on what my mph might be after install any ideas? will be running 14 psi!! freakin cant wait!!!!!!!!!!!
Old 04-14-2009, 11:02 PM
waterbug1999's Avatar
You only made 440hp on a 408? Low compression?
Old 04-14-2009, 11:14 PM
it made 440 at the wheels at 5800 rpm i bought the car already done it probably needs re tuned but will just wait and have it re tuned after the install!
Old 04-14-2009, 11:15 PM
cool deal.... should be a sweet set up.
Old 04-14-2009, 11:19 PM
yea i hope so!! just had rpm transmission build a level 5 for me shifts awesome!! weak link is the stock 10 bolt haha 12 bolt moser on the way soon though! your car looks sweet also !!!
Old 04-15-2009, 04:35 AM
EPP
EPP's Avatar
Thanks for the order, you're going to have a lot of fun with it! Bob
Old 04-15-2009, 10:20 AM
LS1RedZ's Avatar
Like the others have said. You will definitely have fun with it. I love my D1SC. I cant wait until I can upgrade to a F1C.
Old 04-15-2009, 12:55 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Yep, its gonna be sweet! Do you happen to know what the compression is on your engine? Ideally, you want 9~9.5 with that setup. If you are running 14psi with higher compression, you may want to look into a meth kit. May not be a bad idea anyways even if you are in the target compression range.. Good luck with it all.
Quick Reply: just bought a pro charger d-1sc
