2 step What exactly is a 2 step and do I need one? Thanks guys |
Originally Posted by koji777
(Post 11458072)
What exactly is a 2 step and do I need one? Thanks guys It's like the factory rev limiter that you can set any rpm desired. Only it cuts spark instead of fuel. This will cause a turbo to spool up faster. You don't need that with the blower BUT I like them because I use a trans brake. While on the break I set the 2 step at 3k rpms. I can sit there for long periods of time without hurting/heating up my transmission. |
© 2024 MH Sub I, LLC dba Internet Brands
