anyone who had the magnacharger on their f-body- need advice
Old 04-22-2009, 09:54 PM
Blacklightning744's Avatar
Default anyone who had the magnacharger on their f-body- need advice
hey guys so here is my question, im lookin to go all out on a magnacharger motor for my 2002 ws6. i need recommendations for pistons and how much -cc's, along with block sizes. heres my setup so far, Eds mp112 magnacharger kit, simens 60lb/hr fuel injectors, TSP stage 3 LQ9 heads, EPP F/I Camshaft, double roller timing chain, ported oil pump, chromemoly pushrods. im thinking about going with SLP's 402 Iron LS1. any advice is greatly appericiated.
thx guys,
Tom
Old 04-23-2009, 06:44 AM
martinls1's Avatar
From what I've heard, the 112 will be to small for a 402, might have to consider a 122
Old 04-23-2009, 08:42 AM
FastKat's Avatar
I think the TCS 1.9 or 2.3 would be best for your setup, since you are running a 402. The MP112 is a little small for an all-out setup.
The price difference through Magnacharger is probably small given the price of the entire kit. If all-out is your goal, I think the TVS series would be the way to go.
Then again, those guys might be giving MP112 kits away to clear out their old inventory... I don't really know. I called them a couple weeks ago for some info and the immediately tried to sell me on the MP112 kits. I had to ask specifically about the TVS kit, and then I got some info on that.
-Dave
Old 04-23-2009, 08:43 AM
CTSV_510's Avatar
You're going to have issues getting much boost out of a 112 on a 402.
Old 04-23-2009, 03:48 PM
o yea def i want to go with the TVS blower, but its getting it to fit under the cowl, thats the problem, im thinkin about hackin up more out of the firewall, then what Ed has done on his kits, the reason why i wanted 2 go with the mp112 is because thats the only one i have seen that fits lol. if n e one has put n e thing bigger on an f body please let me kno, u have my complete attention.
Old 04-23-2009, 05:19 PM
martinls1's Avatar
What are your numbers on your current setup? Any track times?
Old 04-23-2009, 08:56 PM
BadMonkey's Avatar
You would be better of with a 346 - 370 block (forged). Torque down low will be nuts. If you are dead set on going with a 402 or have one, you'll have to overspin the maggie to make the power or go with a Procharger or Turbo setup. I loved my maggie though. The lowend is insane.
Old 04-24-2009, 12:16 AM
LilJayV10's Avatar
LM speed is suppose to have a TVS kit now. Ed sent me a PM about it over a month ago but I have not seen any pics yet.
Old 04-24-2009, 06:01 AM
EPP
EPP's Avatar
You would not be happy with anything smaller than a 2300 on your 402. The 112 would not give you the boost you're looking for. Bob
Old 04-24-2009, 06:03 AM
gotcha so 402 is to big for the little maggie, ok so that answers that question, so now 2 my others,(1) what would be the best pistons for it, and (2) i want 2 aim for 650-700 rwhp and maximize the blower, does n e one think my setup that i have listed, in the first thread can produce that much power. like i said n e advice is greatly appericiated, ill try and contact Ed and see if i can get n e info on the TVS kit. as far as my rearend setup goes, im not goin n e where past 3.73 gears assuming i can even hook up with those gears
Old 04-24-2009, 07:37 AM
EPP
EPP's Avatar
I really have my doubts that the 2300 will fit.
Check out our complete LS2/402 shortblock, the parts listed in it our what we use and recommend.
3.70 gears are a great way to go. Check out my '99 Camaro at this link, which has 3.70 gears. http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old 04-25-2009, 12:10 AM
well a magnuson 122 will be sufficient enoungh check out kenny duttweilers engine, it made over 700 horsepower on pump gas with the 122 which i beleive will fit given enough persistance, i must say though i read through the page on ur camaro, it is one impressive piece of machinery, kudos
Old 04-25-2009, 07:32 AM
Fryguy302's Avatar
Where can I get info on the big magnuson kit? We don't have to worry about clearing the cowl.
Old 04-25-2009, 08:23 PM
98catfish's Avatar
That was on an engine dyno. Its going to take a lot of tuning and a 370-383ci motor and a big damn blower cam and a **** load of boost to get 700 rwhp.
I will prove it within the next 2 mos, Thats the build i'm working on right now.
Doug
Old 04-25-2009, 11:19 PM
Doug
granted, but it would still make easily into the 600 numbers, btw what kind of pistons r ya plannin on running.
Old 04-25-2009, 11:32 PM
ehnihl's Avatar
I have the same question...Thanks for the input...
Old 04-26-2009, 12:10 AM
out of curiousity, n e one think one can fit a harrop blower under that cowl
Old 04-26-2009, 01:36 PM
FastKat's Avatar
I think Harrop runs Eaton TVS units just like Magnacharger, but I could be wrong.
Old 04-27-2009, 04:03 PM
farmdawg's Avatar
I ran a forged 347 with small valve reliefs on mine, 243 heads, blower cam from Comp Cams, Kooks 1 7/8 lts, and spun mine to 10lbs of boost; I used the thicker MLS gaskets too, with a tune from Vengeance when they came out to Hawaii and drove my car to tune it I ended up with 545rwhp and 550rwtq.
I would recommed forged pistons with a slight dish to help drop compression to be able to use more timing and get more power out of your setup. I could have run meth or some other charge to increase the timing, that would've gotten me closer to 600s. A few more cubic inches would help out too, but I would reommend staying under 400, more like 370-383.
The off-idle torque and power wit the maggie kits is insane, mine was a daily driver with tire-smokin capabilities at will. I could be driving 70mph on the freeway turn off the traction control, mat the pedal and send the tires up in a smoke show. Then I decided that I wanted a Vette and let it go, dumbest thing I've ever done!!!!
Old 04-27-2009, 08:25 PM
EPP
EPP's Avatar
Thumbs up
Thanks, I appreciate it! Bob
Quick Reply: anyone who had the magnacharger on their f-body- need advice
