tial q blow off valve
Old 04-23-2009, 10:12 AM
dpinson's Avatar
Default tial q blow off valve
i just ordered a tial q blow off valve and got the pink spring with it but they were saying it was a 12 psi spring. i only see options for 11psi.but they say the new tial q has the 12 psi spring which is the same as the 11-psi spring(pink one) for the 50mm
is this correct?(for a superchargered application)
or is there 2 different pink springs 3psi and 12 psi?
thanx,Daman
Old 04-23-2009, 10:38 AM
Grr
Grr's Avatar
yes there is a ping 11psi and pink 3psi, be sure to get either the 3psi or 6psi. No one really sells them with the pink 3psi spring so you have to order it from Tial
Old 04-23-2009, 11:16 AM
TiAL's Avatar
yup, the 11/12psi spring is pink and the -3psi spring is also pink, but MUCH smaller/shorter
