7-SYi supercharger help!!!!!
I just recently came across a 7-SYi supercharger for my LS2 and i need some help on it. #1. the unit came with a 8-rib 3.125 on it. and i want to change it to a 6-rib but dont know size to use. im using my stock balancer.so which one to go with? these are the one's the sheet show that are good 3.40, 3.60, 3.80 or 4.00?
So it points to me, he's trying to fit this unit to a stock engine. Which in that case....I'd think a 6 rib would be fine.
I fitted my YSi to a stock 346 when I first started, the 6 rib worked just fine
Although admittedly.....it only stayed that way for about 3-4 weeks lol.
the only thing i chainged was the cam and the lifters(LS7's) 60lb injectors. later i will change it to a 8-Rib since i have sum of the pullys already. this is my first time going with any set up like this. so try'n to get all the info i need. what kinda boost i can get out of it?
