396ci + D1-SC New #'s
I've always been pretty happy with how much power my car made, previous best was 639 RWHP, 656 RWTQ on the LS6 intake and 18* timing.
Quick Stats:
9.5:1 396ci 7.65" crank pulley
D1-SC - 3.4" blower pulley
AFR 205's
Stalled 4L60E (3200 Vig triple disc)
Moser 12 Bolt
3" Steel DS
12" wide Fikse's
I found an old article from GMHTP where a procharged SS picked up substantial power going with a Vic. Jr. and a 90mm TB so I thought I'd give it a shot. It seemed to work out pretty well and here is a shot of how the engine bay looks and the new numbers!!
Here's a pic of the engine bay setup:
New Numbers
Old intake comparison
The car saw 18 psi through the D1 (225 kPa), I'm freakin' pumped!!! Thoughts/opinions/comments welcome.
Quick Stats:
AFR 205's
Moser 12 Bolt
3" Steel DS
12" wide Fikse's
New Numbers
So the old numbers were without the 396ci's or with.
I picked up a Vic JR as well and that is nice to see that there was a gain with it....hope I see a few horses out of it....sure does look nice though
Congrats on the numbers, are you going to do a FMIC or stick with the dual IC's?
Jeremy
Jeremy
Thanks! Break granted supersix, for a week or so .
Old graph was also the 396ci., Vic Jr. is the only new addition.
Doubtful, the car held full boost all the way through previously, no drop and zero belt dust on the blower. It is on the exact same belt/tension with this intake as well, no change.
7 Second Club
Hmm, then I have no explanation as to why the old dyno curve is so weird looking if the intake is all that was changed with more boost. Something was up before with it though for sure and I think the gains you are seeing are not really attributed to the intake alone with the exception of the additional boost. Maybe the boost didn't drop off but it held steady and wasn't rising like it should have been? It also looks like the intake is definitely not as good below 4500 rpm as it matches the LS6 intake below that with 3 more psi.
7 Second Club
It definitely isn't the intake that was causing the problem, seen so many that I can't even count that haven't had that issue with the LS6 intake. Bout the only time I have seen that type of curve on a procharged car was with boost leveling off or dropping due to belt slip, blower is just out of steam, or valvetrain issues. The D1 definitely wasn't out of steam and you say there wasn't any slip and boost was rising as it should and the valvetrain is identical so I am out of ideas. lol
