Where do you drain oil on front-mounts? Pics please
As title says, where do you drain oil from turbo? On the builds I see (with truck manifolds) turbos sit way too low for the gravity drain, do they all use dedicated drain pumps?
Please post pics of your setups
damn it must be nice to have that kind of room up front, on the gto i dont have **** for room under there, if i did all my **** would be on. i got a question too, did you drop your pan to drill?
it is a good ideal to drop the pan when you want to drill it. but is is allot of work and most people just use bearing grease on the drill bit to catch most of the shavings.
The oil drain plug hole is not a really a good location for a gravity drain.
The oil that drains from the turbo will be a little frothy, so it is best to let it fall into the engine oil so the air bubbles work themselves out.
I would not want the drain near the pickup if I could avoid it.
You need the turbo drain to be ABOVE the oil level in the pan in order for a gravity drain to work. I have my drains in the front cover similar to vee8.
If you go in the side of the pan, try to stay inline with the main caps so that the oil being thrown off the crank at high RPM does not try to make its way into the drain line.
The best location usually becomes a compromise based on your particular setup.
Just grab a section of -10 and use it to eyeball the best location that will not interfere with your existing accessories.
Good luck!
Good luck!
Where mine is located is above the oil level. I made sure of that, but my turbo location pretty much limits me to this area. Everything else is too high.
If my turbo was higher up, the front cover is a better option, much easier to take off to drill and tap it rather than the pan.
You might be right, but the reason is elementary - with let's say 4 inches horizontally between turbo drain and front pan, and 2" vertically, there is good downward slope. Now if you drain oil not 4" away but 12-15" (in the side of the pan), with the same vertical 2" of difference, it becomes almost parallel to the ground
