Boost & power increase going from 3.5" twins to the bigger 4.5" twins?
I have the procharger 3.5" twin intercoolers with a D1-sc on the car now, Switching over to the 4.5" twins, What power and boost increase should i see, doing nothing else?
thank you for your help
I agree, you probably won't feel the difference since you have methanol injection. The larger intercoolers will indeed help to keep the inlet air temps down, but adding the methanol injection will have made the biggest difference. Bob
i heard the 4.5 coolers flow past 14 psi, unlike the 3.5's and where ever your at , max boost on the 3.5's you will pick up one full pund of boost . does this sound right.
i do agree with the methanol injection that my intake temps are very low as it is and by switching over to the 4.5's that i wont make any more power that way but if the 4.5's will free up 1 psi that should be good for 20-30 hp NO?
