IAT's What kind of IAT's are you guys seeing on and off meth and what is a safe level to run. |
85ish ambient...start runs around 100 degrees IAT..no meth end at 140. with meth end at 80 |
I spent some time out with HP tuners the other night. I am not sure but i think the intake air temp is getting to high and the car is pulling timing. This could be why i am seeing very low trap times. Only 11.6 @ 114 boost only and only 117 @ 117 on a 35 shot. I am seeing 165 plus IAT's in the 1/4 with out the bottle on only 9 pounds and thats on a cool NC night. The car should be running 15 deree's of timing but as the air temp goes up its droping down to 6 to 8 degree. |
Thats high wht size inter cooler do you run? I see crusing on a 100+ degree day around 88 degrees and at idle around 110. On meth 78 degrees wot on the high way in 100+ degree and at night when its 85 degrees out my Iats on meth is in the 60 degree at wot. I also run a 50/50 mix and use the biggest nozzle. |
I am running the TTI street intercooler but i dont have the front of the car opened up and i dont think its getting any flow. |
How do you know how much meth to run? Do you just keep spraying more until you see the temps you want or what? |
Im not sure on the meth it ramps up as boost goes up so its all where in the power band you spray it. I have a single nozzle and my intake is custom so thats why I used the biggest one. To cbr. I did the cat fish mod with the gills lol to expose the intercoller and it made a huge diffrance. Look in my photo albums. i would not completely gut the front nose tho. |
Yeah thats what i am thinking. Right now the intercooler is getting no flow and i fill like its just heat soaking. I notice for about every 8F she pulls .5 timing. This could be why i am traping so low and the car stops pulling at the top of 2nd gear. |
This is also on a TA. |
Oh dam do u have the front plate remove? I know it aint much but it may help |
No it is still in place. |
I would remove the plate and cut that area out where it mounts that will expose the intercooler and force air around it. I just thought bout it how big is the intercooler? |
Originally Posted by cbr600rx7
(Post 12121435)
I think it might help but not sure how much flow its going to allow. |
Originally Posted by SKINNY69
(Post 12121512)
So why do you even have an intercooler? |
This is a good topic, but useless unless more information is included. 1. ambient air temp. 2. iat 3. with meth and mix % and system set up and nozzle placement 4. BOOST.....and turbo used. more boost = more heat. 5. intercooler, size, air flow.. 6. speed the veh is moving when iat is measured and humidity if you can. The most recent numbers I can remember are. turbo van: 1. ambient = 107 2. iat = 107 3. no meth 4. boost = 10 psi with turbonetics 72mm 5. intercooler = cummins 12 valve ram intercooler (in the area of double the core size of a 11x3x24 typical f body intercooler) 6. speed doesnt seem to matter , it stays right around ambient weather its idling or at 10psi at 60 mph.. 7. humidity is less then 15% Zombiess car has logged 65 degree iat in 94 degree heat at hiway speeds. using 11x3x24 intercooler, st80 at around 15 psi using a smc kit. Meth will be on the turbo van in a couple days....and some track testing but the ambient is probably going to be well over 100. |
I am going to try opening it up a bit today by removing the plastic. I also might try lowering the intercooler down right in front of the opening to try and get some more air too her. |
50 50 results on the van....113 ambient.....79/80 degree IAT at 10 psi. Yes 33/34 degrees ...........Last night I actually saw 69 degrees on the freeway at speed (120 ish) with ambient around 94. |
can u take a b4 picture and after picture? lol i cut the entire grill of my Camaro for the FMIC.. i was advised not to but i did it to avoid running into this issue. i dont care if the top is spidering a little - no one can tell (seriously) and its not exactly a show car anyways.. i bought it to make power lol |
I sure can. I was hoping to get started to day but i was replacing a shift cable on my scout (for the people on here that still remeber them) I will keep my before and after logs to see what the change is. |
| All times are GMT -5. The time now is 01:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
