Does anyone have an off the shelf 3.9" stroke crank?
Old 09-10-2009, 01:12 PM
Restricted User
98Z28CobraKiller's Avatar
Default Does anyone have an off the shelf 3.9" stroke crank?
I can't seem to find a 3.9" stroke crank anywhere. The usual suspects will make one but it costs $200-$400 more than a 4" stroke crank.
Old 09-10-2009, 03:01 PM
ls2 bait's Avatar
im sure you have a reason....but why? why not just use a stocker or a 4"?
Old 09-10-2009, 04:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Post in the sponsor forum too.
Old 09-10-2009, 05:23 PM
MUSTANGBRKR02's Avatar
This is the only thing i could find on one.
https://ls1tech.com/forums/lsx-parts...ker-crank.html
Old 09-10-2009, 05:30 PM
ninetres's Avatar
$200 extra for a custom 1-off piece tailored JUST for you doesn;t sound overly expensive to me.
The following users liked this post:
Jimbo1367 (10-02-2023)
Old 09-11-2009, 08:42 AM
turbo'd stang's Avatar
Eagle used to make one.
I have a Callies that is too, not sure if it was custom or not.
Old 09-12-2009, 09:48 AM
Restricted User
Exactly. But now they dont.
Old 09-12-2009, 10:11 AM
Restricted User
Piston rock. Here's a thread where it is discussed. Many say that it is a problem that happened early on but since then the piston manufacturers have made changes to the pistons that eliminate the problem.
https://ls1tech.com/forums/generatio...ston-rock.html
I personally had an LS2 402 that came apart with beat up skirts. The problem is that a race piston usually has some tapper in it so that as it gets hot under extreme conditions, the top of the piston has a little room to grow in the bore. When you drive the car alot and the piston isn't seeing the extreme conditions, the piston is rocking in the bore at BDC because the LS1, LS2 sleeve is short. I've heard some say that the iron block's bore is a little deeper but my engine builder doesn't agree.
My goal is to turn some RPM's with the new motor, have it be as reliable as possible and burn as little oil as possible. I'm probably just going to use the stock crank right now.
Old 09-12-2009, 12:16 PM
toretto's Avatar
still going to rock the turby?
Old 09-13-2009, 08:16 AM
Restricted User
I'll be using the same kit with the same turbo. I'll just be moving more air with the new longblock.
Old 09-27-2023, 08:38 PM
R.sporay's Avatar
Because with a stock block piston comes to far out cyl,to run twin turbos, best to limit stroke to 3.750 witch is more than stock crank for 6.0LS .
Old 09-27-2023, 11:38 PM
Zmg00camaross's Avatar
14 year old thread!
Project GatTagO (09-29-2023)
Old 09-30-2023, 07:49 PM
Amusa's Avatar
Old thread!!
Quick Reply: Does anyone have an off the shelf 3.9" stroke crank?
