Forged Iron 370 / AFR 225's / Truck Manifolds / PT88
#64
Ill be there by 7pm at the latest. My car usually doesn't have traction issues but the test & tune prep has been sucking pretty badly lately from what I have seen. Hopefully it isn't an issue for me.
Got some passes in tonite between the rain. No good launches due to poor conditions. They didnt get the track dry until late but kudos to them for not raining it out. Anyway, I found a leak at the exhaust manifold gasket and I got some data. Not sure how to feel about the outing right now. It went 10.08 @ 127 (coasting because I hit the limiter about 50' out) @ 12 psi with a 1.60 60'. On the stock longblock it went 10.002 @ 129 (also coasting) @ 17 psi with a 1.38 60'. That's good I guess. I also had 3 more mph @ the 1/8th.
#65
It will take some getting used to but ive been watching your thread from the start, and sounds like you know what your doing. Im also building a 377 t88 nitrous car and watching your car come to life just gives me more hope to work on mine.
#71
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'd say that at the current 12 psi, it will run a 9.5 @ 142 @ 3700 lb race weight. Should be about 800 rwhp if my benchracer brain dyno is accurate.
#73
Going down the track, I was stalled up at 8 psi on the transbrake and the 2 step at 4K RPM. When I let off the button it gets to 12 psi almost instantly. So on the track, no lag.
On the street, if I'm cruising at 60 mph (2900 RPM), There is no boost. If I mash the gas, it stalls to about 4200 on the converter and starts making boost. It took about 1.5 seconds to be at full boost without braking boosting. Not sure if it will happen faster with the CO2.
I'm on water with water wetter already.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Got a blanket but haven't gotten around to putting it on yet.
#75
I got all the new vacuum lines and fittings in. Everything was 1/8 pipe except for the port on the Aeromotive fuel pressure regulator. It is 1/16 female. Apparently a female 1/8 to 1/16 male is really difficult to find. The local hose and pipe store ended up making me one for $7 bucks. I just need to drill the firewall and put in the bulkhead fitting for the CO2 and fill the bottle.
I also had a friend make me some solid mounts. That should take care of that problem. It's going to be a pain in the *** to get the melted ones out while still in the car but it'll be really easy to put in the solids as they have a much smaller footprint.
#77
Just to be clear, We are not doing the pedestal type solid mounts. My friend fabricated steel mounts that attach to a normal BMR Turbo Kmember. And no, he wont build them for anyone else. The amount of time required to make them and the liability that could be associated with it makes it not worth it. Also, becasue the steel doesn't flex like the poly/clamshell type mount, it is not very forgiving at all as it pertains to alignment. I think that my motor moved up 1/2 inch as there is no sag either.
Changed the break-in oil. Looked good.
Also got the CO2 filled today, found the fittings required in order to backfill the 10oz bottle from a 15lb mother bottle, and got it all hooked up. Works well.
Gotta do a little tuning tomorrow. She is a little rich up top right now.
I just need a set of tires and I'm ready to give her hell.
#79
We got the solid mounts in. WHAT A PAIN IN THE ***!
do it to it dawg.
How do you like the AMS?
#80
I got the spring in the gate at about 7 psi. Controller is setup to make 12 psi. Got on it in drive and hit the controller at about 5500 RPM. It felt like I sprayed it.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
That's the only conclusive data I have so far. No tuning or data logging today. Too much Halloween traffic.
I got the tires on the car today.
Unfortunately, I'm having some fueling issues. Rather, lack of fueling. The pump isnt cutting off, it's acting more like it's running dry. The tank is full but the pump sounds like its cavatating. I think there might be a chunk of plastic that may have come loose in the tank. These stock tanks on the 98's are metal but they have a plastic liner on the inside and the baffles are also plastic. When we drilled thru the bottom to weld on the bung, it made a pretty big mess. When we welded the bung on, it made an even bigger mess because the plastic in the tank wanted to catch on fire. We cleaned it and cleaned it and cleaned it but some brittle plastic must have broken off in there. The bigger problem now is that I have a full tank of gas that I need to siphon out in order to try to hunt down the culprit. Oh well, it's always something.
