super charger location w/Fbody accessories
i'm in the process of swapping an Fbody set up into a Gbody car. I have the Fbody LS1 with accessories in the original locations. i want to run a procharger, but would like to mount it up high, similar to the location i see on the GTO's. Is there brackets and belts already set up to do this? i thought GTO LS1 accessories were the same as F body, true? So will it be just as easy to mount the procharger up high on the driver side, near the ps pump?
