What's the diff between LG's G5X2 and EPP's Blower cam? Same Dur. & Lift
Blower or turbo? There is a possibility this cam is on a 112. I haven't pulled the timing cover. I'm pulling the motor out next weekend. I might as well spend the $100 and get a cam designed for F/I. I know they work great and make awesome power...this one surges under 1700 rpm and i'd love to eliminate it. Most likely my tuner.
Exactly why I might go a little smaller. 220's just to make it a little more docile around town. Even still, under 2800 lbs it's gonna be violent. I don't think I'll be limiting myself running under 230 dur. The only thing I'll be losing is the lope. Which is awesome except I'm thinking sleeper now, maybe some cut-outs along with cats, corked exhaust and an H pipe.
My turbos flow 60 lbs min. 7 blade 12cm Holset HX35's. Since I'm using the smaller housing, I'm told spool should start early in the rev range, 8-10 psi by 3000 rpm on a sbc. Also my cold piping is only 22'' in total length (intercooler flat on top of motor), so throttle response should be snappy.
I talked to Anthony today and said just send the cam in and let him know what I want...LG ROCKS!!! THANKS GUYS
