Turbo Tech Comparison GT35R--LG--APS(base) Im looking for some information on a few different turbos. I am looking for this information strictly for comparison and for information for others. I have some of the data, but I am have some of the information that I havn't found yet. Any info will be appreciated and if I need to be corrected on any of this feel free GT35R Compressor Ind 61.4mm Exd 82.0mm Turbine Ind 67.8mm Exd 62.3mm LG Upgrades Compressor Ind 59.62mm Exd ? Turbine Ind ? Exd ? APS Base Compressor Ind 52.6mm Exd 68.0mm Turbine Ind 67.1mm Exd 58.8mm Flow GT35R 60 lb/min LG Upgrades 70 lb/min APS 44 lb/min Exhaust A/R GT35R .70 .87 1.06 LG .84 APS .84 gt35 map: http://www.squirrelpf.com/turbocalc/ http://www.turbobygarrett.com/turbob..._714568_10.htm APS(base) map: https://ls1tech.com/forums/forced-in...0-901-a-2.html I would also like to see a flow map for the LG turbos Maybe Louis@LG can step in give us some of the info on the LG turbos thanks |
im not aware of a gt35 upgrade for the aps kit. i heard one speed sdop in texas was "working" on a kit |
he wasnt asking for that. he wants people to fill in the blanks. and i do to. so Bump for Louis. lol |
GT35R specs: Compressor max = 68lbs/min Turbine max = : 0.63 = 23lbs/mn 0.82 = 27lbs/mn 1.06 = 32lbs/mn |
thanks for the info,.................how does it change the flow rate of the turbo when you use, for example, a .70 exhaust housing compaired to a 1.06 housing with the gt35r? Is that 68 lb/min the max the turbo can flow period or does it change with the exhaust housings? |
Originally Posted by bluehawk2
(Post 12920358)
that makes sense.................you just have to get the right exh housings for your combo |
speaking of louis, where is he, hasnt been online/posted in a while? |
Louis's past comments have implied that his upgraded aps units make much more power than the garret gt3582s. If that's true, can the garret gt3582s be upgraded for a reasonable price? |
Originally Posted by bondosgto
(Post 12924285)
that guy is busy as hell all the time, your lucky to get him on the phone because most of the time hes at the track, or on the dyno, or some other crazy stuff |
Forced Perf can do upgrades to the gt35's just like they do for the mits 20g |
Interested in this information as well. Looking to upgrade my turbos this month. |
How does Louis's Upgraded twins APS turbos compare to a single PT88? |
I would think they would fall short of a 88.................there are several diff 88's out there though LG......1200+ gt4718....1400+ |
standard GT35 comp wheel is only 60lb/min not 68 |
Originally Posted by TiAL
(Post 12932398)
standard GT35 comp wheel is only 60lb/min not 68 You have to twist it's tail to get 68................ |
Thanks for correcting me When you look at those maps what do you look for? Where is the max flow on the map. Im assuming that the pressure ratio is the compressor pressure/back pressure. Where is the limit as far as that ratio goes? Just need a little info so I can know exactly what im looking at. |
dumbass question, these fit the gto? |
© 2024 MH Sub I, LLC dba Internet Brands
