View Poll Results: How much power can LS6 Heads handle?
500-599 rwhp
2
5.13%
600-699 rwhp
7
17.95%
700-799 rwhp
8
20.51%
800-899 rwhp
16
41.03%
900-999 rwhp
3
7.69%
invincible
3
7.69%
Voters: 39. You may not vote on this poll
What's the power limit for LS6 Heads?
I'm not an engine builder, but....
I think it comes down to how early you are making the power (ie torque) rather then overall HP. The heads seem to pick-up sooner on Nitrous and Turbo cars and not so much on Centri-S/C cars.
I think the technology is a little better now days but several years ago my rule of thumb was the heads come up around 800 HP.
Something else to keep in mind is alot of those folks making big HP on an LS6 head are picking the head up and pushing water, but either deal with it, or have other means to manage it.
I have almost 30k miles on a 700HP S/C setup LS6 head and no issues so far.
Things have changed a little those number are from the stock 241 heads ls6 intake and 224 232 cam with the t56 still in it.
I have not dynoed it yet with the same forged 347 but with 243 heads that I ported 235/251 cam and Victor Jr intake. And it now has a TH400 That was my second full pass with the new setup and 1.54 60' (same blower pulley combo as last year)
The car has alot more in it with some more seat time and 60' work
Stock heads do lift, so do aftermarket thicker deck heads. When the heads are going to lift has a ton of factors. How good of a tune, how much time at larger boost levels, what rpm the power adder makes full boost, head gasket, studs, ect , ect. I have had several cars at 800 rwhp or so with no leakage at all. I have had a few cars at 900 rwhp that showed some leakage at the bottom of the cylinders but no blown head gasket.
If you want to be loved... be lovable. Damon Wayans
Spoken with the vagueness of a politician caught with an underage hooker... If I had a nickel for every time I heard "it's in the tune" I'd rent a movie or something. As a tuner myself, I'm interested in how a tune can make the head hold together, brother? I'd like to know because busting a head is going to cost me a few years worth of movies, not to mention months of downtime. Please share your secrets with the team and I ain't talking bout your grammy's crawfish etouffee recipe. Dan
If you dont think the tune has to do with anything, highlight your timing table and add 15*. Then report back on how your pistons, bearings, plugs, and head gasket look. Your motors survival is without a doubt "in the tune".
Controlling cylinder pressure is how you keep a head down. You do that with the correct a/f ratio, the right amount of boost, and timing. There will be a point when you are going to excede the motor's mechanical limits but someone who has a clue will get much further safely.
#32
don't make the cajun angry, you wouldn't like him when he's angry
#33
Power limits are limited by their ability to stay on the block because of the 4 bolts. People can reliably put down up to 1000 rwhp with oversize studs and o-ring job and the right gaskets. At the 1000 rwhp level its better to step up to 6 bolt heads with a thicker deck. I would even above 800 rwhp for added insurance.
#35
I remember seeing a thread on here a few months back about someone making 1000hp with completely stock 317 heads. I can't remember the details, but i do remember they were completely stock unported heads.
Saying it is in the tune is very true. I think most piston failures, and blown head gaskets are due to other factors than simply pushing them past their limits. Small amounts of detonation, or excessive cylinder pressure because of poor timing setup will cause destruction quickly.
#40
650rwhp on dyno but had lots of tire spin
3800 lb car doing 140 in 1/4 is 800+ rwhp and I can drive it anywhere not just track car
