Make boost earlier?
Old May 29, 2010 | 02:19 PM
JC70SS's Avatar
Default Make boost earlier?
Right now my car is getting into the meat of the boost at 3500rpm. How can I bring that down so it is making boost earlier?
Old May 29, 2010 | 02:54 PM
dimetweaker's Avatar
Naaawwwwwwwwwzzzzzzzzzzzz!
ahh time for some edit, i was thinking you were turbo, so that changes everything. GET NAAAAWWWWWWWWWWWZZZZZZZZZZZ!
Old May 29, 2010 | 03:11 PM
1320's Avatar
I ve always wanted to say this......if your blower car has to much lag then its time to go turbo.
Old May 29, 2010 | 03:42 PM
youngrigo's Avatar
Smaller pulley and a restricter plate or wastegate
Old May 29, 2010 | 04:07 PM
XtremeDime's Avatar
Nawwwwwwwwwwwwwwz
Old May 29, 2010 | 04:17 PM
JAX04's Avatar
This is about your only option, there are a couple really good threads on here regarding wastegates on supercharger cars.
or, as stated, time to go turbo! FTW!
Old May 29, 2010 | 08:50 PM
elias_799's Avatar
raise the compression of the motor, should give you some more meat at the lower end. just make sure you run proper fuel
Old May 30, 2010 | 12:57 AM
Snyper's Avatar
Not sure why anyone would need power under 3500? thats when everything starts..on the street youll just burn the tires and at the track you launch higher...
Old May 30, 2010 | 12:47 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Since you have a forged engine, and assuming you have enough fuel, I'd put a smaller pulley on it to spin the blower faster. You'll make more boost overall and the boost will come in sooner. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 30, 2010 | 01:05 PM
Aster's Avatar
The only way to increase boost at the bottom is to pulley the blower down so it spins up faster. If you don't want more boost up top you can play with restrictor plates to limit the max air flow.
Old May 30, 2010 | 09:04 PM
71 chevy's Avatar
e85, e98 or e100 .will make it spool a lot sooner
http://www.yellowbullet.com/forum/sh...6&postcount=12
Old May 30, 2010 | 09:23 PM
Aster's Avatar
No it won't, his isn't a turbo car. The fuel won't change the air pushed by the supercharger. Also I'd wager most of your added response was from the removal of the intercooler.
Old May 30, 2010 | 10:25 PM
71 chevy's Avatar
my bad, I didnt see it was a supercharger.
