ATI j-tube w/ surge and Race bypass vavle? When I purchased the j-tube w/ surge recently (haven't received it in the mail yet), I thought it was designed to have the race bypass valve plate welded to it. Now that I looked at it again, it states that it is for use with the Pro-flow bypass valve. Does anyone know if the diameter of the surge pipe on the j-tube is the same or similar to the inside diameter of the race bypass valve plate? This is the tube I purchased: http://shop.brutespeed.com/ATI-AIGJ1...AIGJ1I-005.htm This is the bypass valve I have (I didn't get it with the little tube or the vacuum lines): http://shop.brutespeed.com/ATI-3FASS...-3FASS-004.htm |
The J tube is indeed for the Pro-flow valve, ProCharger doesn't offer a tube for the Race Valve for the LS1. Thanks. Bob |
Originally Posted by Bob@BruteSpeed
(Post 13441632)
Originally Posted by ss.slp.ls1
(Post 13441652)
Do you know how far off the diamters are if I wanted to weld the plate of the race bypass valve to the port on the j-tube? http://i226.photobucket.com/albums/d...hoto/GTO13.jpg I don't recall the size differences, but they are substantial. It woulds be best to do it by removing the tube on the j-tube, and welding the race valve bung in it's place. Bob |
(Post 13441854)
http://www.procharger.com/store/imag.../3FASS_005.jpg http://i226.photobucket.com/albums/d...hoto/GTO13.jpg I don't recall the size differences, but they are substantial. It woulds be best to do it by removing the tube on the j-tube, and welding the race valve bung in it's place. Bob |
The race bypass flange expects to be welded to a 2.5" diameter pipe. I would follow Bob's advice, have the small 1.25" piece removed from the J pipe and replace it with a 2.5" piece of pipe. |
© 2024 MH Sub I, LLC dba Internet Brands
