Smallest turbo of physical size for a built 408 TT
The backstory: I am planning on building the engine, amongst other things, in the G8 GTTT here soon. Still deciding whether I should end up going with a stock displacement forged shortblock or a forged 408 shortblock since the prices aren't terribly far from one another. I currently am running a pair of Garrett GT2871R's which spool very well on the 364ci stock engine and are tucked down beside the transmission in a similar design to what APS uses. This is ALL street car, with a little bit of weekend dragstrip racer mixed in which means I care more about spool and boost response than all out maximum peak power.
The Question: Since the GT2871R's are a bit on the small side, when it comes to flow, for a 408ci engine what turbos of similar physical size (to fit beside my transmission) would you recommend? I know of quite a few turbos that will flow what I would want with a 408ci engine but the issue is verifying their physical size so that they will actually fit into the space I have next to my transmission. And recommendations would be appreciated.
Thanks.
Thanks.
I understand that you are trying to help by offering suggestions but please re-read the first post of this thread. I am not asking for general recommendations of turbos; especially not in single configuration. I am asking with specific regard to physical size (not just flow ability) of the turbos due to the location they would be going back into. Right now I am running twin Garrett GT2871R's down by the transmission and it is tight down there. I was looking for suggestions on turbos that would be physically small to allow proper fit down there but also flow well enough to support a little over 400 cubes too.
I am aware of the Precision 6062's already having been used in a similar build, but on stock cubes, on the G8 in here but I am looking at all options rather than just playing copycat.
I do appreciate your input but my question is very specific here.
Shawn, did you use the T3 Vband inlet from precision? Also do you think if you stepped up to a 62mm or 67mm precision and ran the same compressor cover as the 58 would limit the turbo to much?
Sorry didn't see this reply earlier in the thread. I am only running the stock 364ci bottom end right now so the GT2871R's aren't maxxed out as of now. However, when I do the 402 they will be. Great turbo's, just not quite large enough for where my car is going.
