Notices
How to DIY build a truck manifold turbo kit!
Old 04-20-2012, 02:12 PM
  #121
plan on doing a 5.3 WITH A/C...will i need a LsX k member?? any way this is possible?? need ac.
slomarao is offline
Old 04-20-2012, 02:33 PM
  #122
asb2106's Avatar
Is there anyone fabbing up this piece and selling it?
Im assuming there would be a market for it, and it would fit quite a few applications. Ive got something like that in mind for my truck. But I also know welding is not one of my best skills, and usually I leave that stuff to the pros
asb2106 is offline
Old 04-24-2012, 07:07 AM
  #123
Captain Double Post
Asb, modular turbo sells that part your looking for
BOBS99SS is offline
Old 05-07-2012, 07:56 PM
  #124
great write up!
speedfreak90 is offline
Old 05-23-2012, 05:21 PM
  #125
KILLER-LS1's Avatar
Updated first page with new pics and info!!
KILLER-LS1 is offline
Old 06-25-2012, 06:47 AM
  #126
TOYBOX's Avatar
Nice write up!
TOYBOX is offline
Old 06-27-2012, 08:53 PM
  #127
Default Axle ratio tire size
When you went 202mph, what trans gear did you run, what axle ratio do you have and what tire diameter did you run?
Thanks, Peter
petercalaguiro is offline
Old 07-12-2012, 11:58 PM
  #128
InsaneDomestics's Avatar
That's a beautiful lady, She makes some power and I'm diggin that color.
InsaneDomestics is offline
Old 07-14-2012, 08:53 AM
  #129
I used this info to help get me going on my own DIY setup... thanks for taking the time to post! Very helpful!
AFish66 is offline
Old 07-28-2012, 09:03 PM
  #130
waterbug1999's Avatar
this will be just for looks... you guys think there will be any problems with these shortys? The plan would be to cut the ends off, add some length then weld on the v bands. Im assuming if I do that, I can keep the alternator down low in teh stock position.
For an 02 - 05 5.3L Avalanche. Only 200 bucks.
waterbug1999 is offline
Old 07-29-2012, 01:02 AM
  #131
KILLER-LS1's Avatar
The problem with forward facing tubular headers is that one of the primaries usually will hit the steering shaft. So if you dont mind cutting up a primary and moving it around a little bit, it should work.
also the factory manifold will hold in heat better since it is cast iron... which would help spool
Old 07-29-2012, 02:27 PM
  #132
gotcha... didnt think of that, thanks.
Just got a few parts in the other day, plan is to do a similar front mount using a GT50-88.
Old 07-29-2012, 04:23 PM
  #133
KILLER-LS1's Avatar
Sweet! Good luck on the project!
Old 08-10-2012, 05:16 PM
  #134
Nice write up!!! Im starting my build now a lil different 94 impala SS. I already did the ls swap but spun a bearing now im about to drop a lq9 in
dirty94SS is offline
Old 08-16-2012, 09:00 PM
  #135
badmfkr's Avatar
excellent write up
awesome car
didnt read intire thread
in the mile time trail ? if you keep going what wold your top speed be & how long & far would it take to achieve top speed?
ever concider Boneville salt flats
badmfkr is offline
Old 09-25-2012, 09:36 AM
  #136
MertezWS6's Avatar
I just seen your car in GM High Tech magazine, congrats!!!
MertezWS6 is offline
Old 10-08-2012, 01:31 AM
  #137
I was reading the magazine congrats by the way and I was wondering if your turbo was a t6 it said that the t4 wasn't giving you enough I've been chatting with a turbo company and they said the t4 would put be at 1000 rwhp on my 6.0 with a 3.90 stroke and can run up to 7400 rpms without choking out
Kurtis2short is offline
Old 10-22-2012, 06:33 PM
  #138
verys weet setup! Will be borrowing some ideas to do this on my first gen. Busget and turbo can go together
geberhard is offline
Old 11-11-2012, 08:22 PM
  #139
Default setup
first off congrats nice writeup.
my question is wouldnt it be easier to do a rear mounted turbo setujp and just pipe the intercooler and intake?
dually681 is offline
Old 11-12-2012, 10:23 AM
  #140
hmm not a lot of space, but pretty sure one could get creative
Quick Reply: How to DIY build a truck manifold turbo kit!
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
