How much power? Ok guys I have the 383 in my car. It will be dyno tuned in the next few days. Mods are as follows, 383, Mallet Cars fully ported LS6 heads, Comp 921 springs and hardened push rods, Brute Speed forced induction cam, Fast 90/90, TSP 1 7/8 headers, TSP True Duals, Performabuilt Level 2 tranny and Performabuilt 3500 stall, Racetronix pump and hotwire and 60lb injectors. Car still has stock 10 bolt rear with 323 gear. Will be upgrading to a 12 bolt next. Now I know autos don't dyno well. This motor is set up for boost and I will be putting a ProCharger on next year. But what do you guys think it will make right now? Guess away.:D |
I'll say you'll pick up 60 rwhp with our cam on your for now N/A motor. Take a look at the info I have at this link regarding 12 bolts. https://www.brutespeed.com/rear_end_information.htm Bob |
Well i can tell you that 10 bolt isnt going to last too long on the street or strip. You also dont see a ton of power loss from the T56 to the 4L60 maybe 3-4% more at the most. I would say around 430-450 running a FI cam with lower compression. |
Originally Posted by Bob@BruteSpeed
(Post 13664006)
Originally Posted by cbr600rx7
(Post 13664206)
Originally Posted by 98LS1auto
(Post 13679241)
Bob you didn't make a guess.:jest: |
© 2024 MH Sub I, LLC dba Internet Brands
