Any maggied ls1's out there?? just wondering if there are any maggie ls1's out there, what your dyno #'s were and what your mods were. let me know what type of maggie (mp112 etc..) pulley used exhaust mods throttle body size cam heads and transmission thanks!!!:nod: |
wow, none? |
mp112 max out around 500rwhp. Only a couple people have squeezed 550hp out of them. mp122 is good for >600rwhp, so are tvs 1900 and 2300 |
hmm i too was wondering about this. seems like every one is either procharger or turbo (i'll probably get a response 'for good reason') i was recently looking into them |
I've got an mp112 in my garagae, I would be pretty happy with 500hp.mods will be... Radix mp112 magnacharger (innercooled) 2.9" pulley 60# injectors Lingenfelter GT2 cam 1 3/4 lt's No cats Slp loudmouth exhaust Ported 78mm TB Though a 6speed with a 9" Any guesses on power? |
I wouldn't get caught up in peak numbers with a maggie as much as I would a centri. The maggie should really shine in the low to mid range then kind of level off after that. Maggie's are good for great power/torque all over teh rpm range. |
Originally Posted by DaytonaFIC6
(Post 13760723)
Soooo 480+? Im going to need to change my gear ratio, I currently have in 4.11's and a locker, I wouldnt mind ditching the locker, what gear ratio would be good for a 6 speed and a maggie? 3.50ish? I dont want first gear to be useless. |
I used to have one on my daily, it was fun off the line and at 60, if I stomped on the pedal, it would still send the tires up in smoke. Mods were: Stage 2 Livernois heads 243 castings and 72 cc chambers Comp blower grind cam, SC3 226/234 .598/.599 on 117 lsa Caddy racing lifters, Thunder Racing 7.4 pushrods Kooks 1 7/8 LT headers with Magnaflow high flow cats 3" intermediate pipe and Hooker catback DMH electric cutout MP 112 with 2.9 pulley for 10psi Forged 347 TSP bottom GM MLS gaskets Stage 2 tranny with loose as hell Fuddle 3400 stall Accel 44# injectors Walbro 340 fuel pump and Magna boost-a-pump On a 3:42 rear gear and custom tune by Vengeance it put out the numbers listed in my sig. |
stock bottom end ls1, tvs 1900, stock heads blower cam, long tubes, no cats and all the usual stuff 9 psi 510 rwhp, 535 rwtq 6spd 3:70 gear I could change out the heads but I don't think there is much hp left with this combo. |
should have my tvs2300 up and running in a few weeks, I am keeping the stock cam for now, so I'm hoping for mid 400's at the wheels... Most LS1's dont run maggies because they dont fit 4th gen f-cars witout cutting |
ahhh, I see, i have a third gen, its nice not having the motor in the firewall. farmdawg, why did you sell it??? |
now those of you with a 4th gen f body and own a maggie. do you have the stock ss or ram air hood? |
I just tuned a CTS-v with an LS6 in it... Maggie twin screw SC... guy has a cam with a decent amount of overlap and we only got about 6psi from it even though he was pullied for 12.. made 515/535 a 50 shot of the giggle juice got him over 600 ft/lbs of torque to the ground. |
Originally Posted by Wimimc
(Post 13771341)
now those of you with a 4th gen f body and own a maggie. do you have the stock ss or ram air hood? and FYI.. the new maggie kit fits under the stock hood theres a 1/4" trimming of the cowl plastic that you have to do..it can be done very easily... and you still keep the weather strip fully in tact |
Originally Posted by soundengineer
(Post 13771561)
and FYI.. the new maggie kit fits under the stock hood theres a 1/4" trimming of the cowl plastic that you have to do..it can be done very easily... and you still keep the weather strip fully in tact its intercooled and everything? i searched around for maggie kits but would you have a link to one? |
(Post 13772211)
well i figured about the cowl part but thats interesting about the the kit. its intercooled and everything? i searched around for maggie kits but would you have a link to one? just one of many places that sells them...this was teh first one that popped up in google when I searched for Magnacharger mp112 |
MP112 Stock pulley Pacesetter LT's into a 3" ypipe. Magnaflow muffler 90mm T.B. MS3 cam PRC stg 2.5 5.3 heads Stock T-56 551rwhp/487rwtq on a mustang dyno. This was when it had 411's in the 12bolt. Now it has 373's. Its getting dynoed again in Sept on a dyno jet.:D |
Originally Posted by 2000navyws6
(Post 13772315)
No, just pump gas. I also have a ls7 clutch with the ls2 flywheel. lol yea i didn't plan on putting the blower on before I did the heads/cam package. I know its not ideal, but so far its been awesome. I'm interested in seeing what your combo makes, sounds like it'll be a pretty stout set up man. |
| All times are GMT -5. The time now is 10:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
