Please help ( tried search no luck) wastegate question
The more boost you run, the less wastegate you need, so with 22psi, you should be fine. Even running low-boost off just the 10psi spring you should be ok. I don't see boost creep on my 10 psi spring and I run a 38mm tial. However, do your turbos have t3 or t4 housings, and what's their a/r as backpressure plays a roll as well?
