finally maken the switch from NA to FI tell me what u think about my setup
going from whats in my sig to what im going to list
still will be a 370 but will be 9.7.1 comp
stock crank
eagle h beams rods
diamond pistons -15
full arp hardware
2.5 tsp ls6 heads 60cc
051 mls gaskets
675 spring kit
speed inc tu2 cam
eledabrock pro flow intake
3 bar map
grinnith rad fan tech slim fans
turbo kit
6.0 truck man
2.5 hot pipes
3 cold pipes
bb tc76 .96
3 inch down pipe dumps by the starter
intercooler same as ky turbo kit
fuel
twin intake walbro 255 one on a hotwire one on a switch
-8 feed
speed inc rails
rail mounted fpr with stock feed as return
80lb inj
100 octane
trans will either be a t56 or i really want to do a muncie t10 m10 hybred with strait cut gear and vgate shifter their couple members on here that have done it
rear end
strange 12 bolt 33 spline detriot locker motive 3.55 gear
wana know what u guys think about it first turbo build iv done i wana run 15lbs and i wana make between 700 and 800 rwh will i make my hp goal is the turbo big anuf i thought it was good to 1000flwh but after searching on hear alot more i see it might not make the power i want and id like to make power till 6500 rpm will try and get sum pics up soon
stock crank
eagle h beams rods
diamond pistons -15
full arp hardware
051 mls gaskets
675 spring kit
speed inc tu2 cam
3 bar map
turbo kit
6.0 truck man
2.5 hot pipes
3 cold pipes
bb tc76 .96
fuel
-8 feed
speed inc rails
80lb inj
100 octane
rear end
