why a turbo 5.3 when there is a 6.0? I was thinking earlier today...if I was going to do a 5.3 swap into my fbody, why not just go up to a 6.0? There is probably slightly higher costs involved with needing a bigger wastegate, blowoff valve, and turbo...is there a benefit from the 5.3 aside from being cheaper? The only thing I really need is the short block from either... Thanks! |
5.3s/4.8s are a cheaper (picked mine up for 150), have thicker cylinder walls, meetier pistons and can achieve a lower CR with untouched stock parts and are more plentyfull in the local jys |
5.3's seem to be a dime a dozen and sell a lot cheaper than 6.0's. Also, with a smaller engine you can make more power on the same size turbo before you are out of the efficiency range. Back pressure is also less of an issue with a smaller engine. |
good info...thanks. something to think about. they do seem to be cheaper but upgrading to a 76mm turbo on a stock 6.0 seems tempting. |
It all boils down to what you want. A 325ci 5.3L would be killer with good rods and pistons and a O-ring. Throw in a decent set of TFS heads and a 91mm Turbo. Good times for cheap. |
same why I am building a 4.6 2v and not a 5.4 4v. Cost and you can still make plenty of power with a 5.3L. Thats the beauty about boost man. Makes up for displacement |
I did the 5.3 because it was cheaper, plus now I'm running the aluminum 5.3(L33) so that is 80lbs off the nose of the car, has the better rods than the lq4 6.0 and it has the 799 heads. I've gone the times in my sig on the 5.3 on 18lbs and off the footbrake. |
Originally Posted by skinnies
(Post 14230513)
I have a 6.0, but Im told stock rods cant take alot, where I hear a 5.3's rods can take alot more! |
OK...maybe I'll forget about more cubic inches if/until I decide to go big turbo and big motor then. |
Originally Posted by evo462
(Post 14232756)
5.3 is a fuse. $250 to replace its a quarter the cost of a 6.0 in my area plus as was mentioned, thicker walls and a smaller piston which means boost is acting on a smaller area(stronger) |
Quit pinching pennies and just do a 370 :devil: |
yup get a 6.0 imo. You can always get there with a smaller motor... but takes more cylinder pressure to make the same power as a larger motor. |
If the tune is good, the weak link between both motors is going to be the rods, which are the same(lm7/lq4 and the lq9/L33). |
(Post 14234462)
If the tune is good, the weak link between both motors is going to be the rods, which are the same(lm7/lq4 and the lq9/L33). Depends on the year.... rods changed. But I still vote 6.0 Had a 5.3 in my lt1 bird with a tc76 on it. Lots of fun =] But if I were to do the same junkyard dog build again I would do a 6.0 |
Originally Posted by Dragframe
(Post 14234682)
(Post 14234736)
Correct which if you read my post it mentions that, the lm7 and lq4 rods are the same, the l33 and lq9 rods are the same(also same as ls2 rods). |
Originally Posted by MillsMotorvation
(Post 14232221)
Originally Posted by 99Z28LS1
(Post 14233757)
(Post 14236556)
So what are the stock 2002 LQ4's good for? |
Unless your tryin to make well over 600rwhp then quit thinking about it so much. Any of them will hold that on a good tune. If your trying to make more than that, then any stock part besides the crank is a gamble. |
© 2024 MH Sub I, LLC dba Internet Brands
