anyone running 15+lbs on a fast 92?
im looking to run 15 to 18 lbs with my 370 in the future but am nervous on throwing too much boost at the fast 92 anybody pushin that much through one without any mods to the intake>
Are you worried about breaking it, like I kinda am? I have a 90 and will be pushing 12psi to it this spring. I thought about selling it tho and just getting the LS6 intake thats being used alot with boost. If you worried about breaking it cause its worth money then sell it and buy an intake that has proven to hold up to boost. Just my thoughts tho. There hasn't been a lot of benefit shown with running the fast intake with boost. Mine was already on the car.
i have a ls6 intake but wouldn the fast make alot more hp and tq than the ls6 i wonder if there are any mods u can do to the fast to make it more boost friendly besides burst panels
I know you can reseal the upper shell. I used black rtv. the map sensor in the back has nothing holding it in so you have to do something to help hold it in. I tapped mine to a 1/4 pipe and used a fitting with a line on it with a clamp to the map, o and make sure you loctite the lil self tappers in the middle under the intake. I spent hours sanding all the lil molding seem lines and the rough areas on the upper lid. If you really want to see how well a LS6 intake does then look up mightymouse on here. His car is in the 8's and is a full street car at 3750#
I've heard mixed scenarios on these one guy ran his 92 to only 12 psi and pulled his intake off after 1 year he said it looked as if it expanded underneath and he lost one screw and some screws where backing out of it but I've also heard ppl sayin they have ran them with no problem idk I'm mixed on what to do right now
we dont have to only use factory intakes, we can use sheet metal or victor series. Although I have seen a few fast intakes work well for my tuner and the setups he has setup..My tuner is Nick at Newtech.
i have a guy that wants to trade me the 102 for my 92 then i have to switch fuel rails and all that junk so ill just rock the ls6 and use the fast for another project or sell it
