2" vs 2.5" turbo piping for truck manifold build
Lately I have seen 2" piping recommended here by various people instead of 2.5", citing increased velocity as the benefit for "lower" HP builds. Maybe I just hadn't paid much attention before, but it seemed like 2.5" is most commonly used.
Id be interested in hearing from people who have fabbed or installed both their experiences between the sizing. I think the 2" hot side piping would be easier to finangle around the engine bay, but at what point is it a restriction? I can't say I've seen any hard data either way, more or less opinions/recommendations.
in for info as well i know phil99vette will chime in here bein that he had some good info before in another thread...
if you still have doubt then go with the 2.5 in had shown to work many times...
or go with 2.25 best of both worlds right... ...
i'd go with 2.25 unless you're shooting for 2000 hp. I'm still learning but i can tell you that i went with 2.25 and it improved spool by approx 500 rpm on my twin rear mount.... phil99vette recommended it and i'm glad i took his advice.
7 Second Club
After looking at countless logs and spool data tied to engine combos the exhaust tubes do play a part in spooling. Just some food for thought....
On a 438" motor @ 40# of boost @ 92% VE and 8200rpm the motor can make 2400hp.
Header tube options:
1.750 = 444cfm
1.875 = 387cfm
2.000 = 340cfm
We noticed when we switched from 1.75" to 2" the spool suffered and the boost rise rate seemed more mechanically limited.
Crossover:
2.50 = 870cfm
2.75 = 719cfm
3.00 = 604cfm
Merge:
4.00" = 679cfm
3.50" = 887cfm
3.25 = 1029cfm
Turbo: T6 housing 1.32
3.25" inlet tapers to a 3" before the turbine
3.25" = 1029cfm
3.00" = 1208cfm
Now seeing other combos that have spool problems show lower air velocities.
On a 370" & 20# of boost & 7200 should make 1100hp....
Most factory 205/215 castings have a exhaust port that measures 1.400 x 1.600
Headers:
1.50" = 276cfm
1.62" = 235cfm
1.75" = 203cfm
Crossover:
2.00 = 622cfm
2.25 = 491cfm
2.50 = 398cfm
Merge
2.50" = 796cfm
2.75" = 658cfm
3.00" = 553cfm
Now I just need some turbo measurements for a T4, The T4 looks to have an inlet with about 5.6-5.7" sq/in of area
Turbo inlet @ 5.65" = 700cfm
Going with a larger tube between the header and turbo will increase the area which will require more time to fill and generate the drive pressure for the turbine. You can go too small....
1.750 = 444cfm
1.875 = 387cfm
2.000 = 340cfm
Crossover:
2.50 = 870cfm
2.75 = 719cfm
3.00 = 604cfm
Merge:
4.00" = 679cfm
3.50" = 887cfm
3.25 = 1029cfm
3.25" = 1029cfm
3.00" = 1208cfm
Headers:
1.50" = 276cfm
1.62" = 235cfm
1.75" = 203cfm
Crossover:
2.00 = 622cfm
2.25 = 491cfm
2.50 = 398cfm
Merge
2.50" = 796cfm
2.75" = 658cfm
3.00" = 553cfm
The following users liked this post:
Homer_Simpson (03-05-2024)
So, if I am reading this correctly, I need to build my log manifolds with:
TRUE 1.5" ID primary
TRUE 2.00" ID "log"
TRUE 2.00" cross-over
2.75" merge into the T4 housing
3.5" DP????
I ask because I am about to order all the stainless sched 10 to build a set-up for my ls1 with a MP T70 Q trim.....
TRUE 2.00" ID "log"
3.5" DP????
7 Second Club
TRUE 2.00" ID "log"
3.5" DP????
TRUE 2.00" ID "log"
3.5" DP????
i know that the 4 into one is best and im goin to try to get that done but if i do go with the log and run the crossover into the back of the log shouldnt the log be bigger then the 2-2.25 crossover?
thanks for all the info phil making me rethink how im goin to do things.. glad its all before i start!
7 Second Club
