At which point should i upgrade to the Procharger BIG red race valve and why?
So im running a ls2 with 4.005 -11cc wiseco pistons, callies 6.125 rods, stock stroke, ported and polished 317 heads .. super vic intake, 80lb injectors with a d-1 procharger with a3.4 pulley... 15-18 lbs of boost exspected... And im wondering when i should upgrade to a BIg red race valve and why... when is the the black procharger bypass no good.. Why cant i run a waste gate like a turbo car.. Im new to the boosted area and would like to know more. thanks
If you are still running the pro-flow bypass, I assume you still have the twin intercoolers?
Another option is to add a second pro-flow on the passenger side tubing in a similar location as the driver side. Its a cheaper option.
You can't run a wastegate because a wategate goes on the exhaust side of a turbo kit.
You can run a blow off valve with a small spring. I did it for years. Not sure if you ls guys have a maf sensor. Do you?
Similar builds run 15-18 lbs of boost...so thats what i want lol... Im exspecting 750 to 800 hp. I running a ls2, wiseco -11 dish pistons, callies 6.125 rods, ported and polished 317 heads with bigger stainless valves, 80 lb injectors, 232/240 .595/.608 115 lsa cam ND d1 procharger with a 3.4 pulley
HOw much does that map sensor cost? PEople are back and forth on this maf/ sd debate... some people say i need to run a maf for climate change back and forth .. IM streeting my car mostly ... but i here is sd is done right there wont be any problems
